TomCrox41
- Joined
- Jun 10, 2012
- Messages
- 45
- Reaction score
- 3
- Points
- 8
Hello Ladies and Gents
I need knowledge...
I had a fluctuating temp gauge and corresponding fault code recently. So I put a new sensor in. That fixed the code but then found car was not getting up to temp. At this point I suspected thermostat.
I fitted a thermostat today, no improvement in temp.
reading temperature with vagcom from engine shows correct coolant temp (85-90 ish deg). So why is the gauge only showing 69-70ish under normal driving???
I pulled battery for 10mins to reset. No success.
Any ideas? Does the sensor need to coded? Or reset?
Car is 2004 S4 4.2
Tom
I need knowledge...
Car is 2004 S4 4.2
Tom
