s4 spring rates
205man Jun 29, 2010
  1. 205man
    205man Active Member
    1,071
    13
    does any one know the spring rates or if there is a difference between the saloon and avant.
    reason being ive just got hold off a complete set of s4 suspension springs and dampers, i was only after the dampers myslef but my friend has a broken rear spring on his s4 saloon and these came of an estate , and we just wondering if there were any differences in rates etc
    also does anyone know the spring rates for the standard quattro sport suspension, because if he doesnt fit them i may put whole setup on mine as less than a third the miles mine has
    alan
  2. Blue_Thunder
    Blue_Thunder Well-Known Member
    1,767
    31
    The saloon's arse end will sit a little higher with avant rear springs, but not badly. A few people fitting RS4 suspension to their S4's noticed this.
  3. aragorn
    17,885
    688
    ye theres a tiny difference on the rear springs, but given going from old busted springs to new ones is quite likely to raise it anyway, i doubt you'll notice all that much.
  4. aragorn
    17,885
    688
    From memory, S4 and TQS rear springs are the same.
    Front springs are different, as the TQS doesnt have a dead horse nailed to the radiator grille ;)
  5. 205man
    1,071
    13
    what about the dampers themselves? are they any stiffer etc than standard sport ones,?
    also am going to do them this morning so any advice or tips would be useful guys
    thanks
    alan
  6. 205man
    1,071
    13
    ok here somethign bit confusinf, we all been saying that the avant s4 had different rear springs to the saloon s4
    so i was looking as this guide to fitting and notice rear spings are paint marked 3 pink 1 white the same as i have have off the avant..........but his car in the guide is a saloon, so either the yanks got a different setup or avants/ saloon didnt nessecarily get different springs
    http://www.audiworld.com/tech/wheel28c.shtml
    http://www.audiworld.com/tech/wheel28b.shtml
    alan
