S4 skirt fitting
floyd 1.8 turbo Jun 26, 2010
  1. floyd 1.8 turbo
    floyd 1.8 turbo Mirror, Signal, Outmanoeuvre
    632
    Do the black plastic sill trims need to be removed to fit the skirts? Offered up the skirts and they seem a bit too proud for my liking. Dont wanna rip the trims off though as theres a shed load of double sided holding them on
    Just wondered if anyone could tell me before get the airsaw out and start cutting things up when i dont need to!!!
    Many thanks chaps
  2. ian52
    ian52 2000 a4 1.8tqs-yellow
    1,199
    The s4 sill trims dont go round the sill like the a4 ones so you will have to cut them.
  3. floyd 1.8 turbo
    632
    Should the S4 skirts go under the doors into the shut?
    As i've removed the lower door mouldings i'm hoping the skirts can be level with the bottoms of the doors or sit inside a bit so the black trim inside wont be seen from the outside
  4. ian52
    1,199
    Yes. The skirt kind of wraps round and sits on top of the sill and the plastic trim should sit just on top of this. You wont see the sill trims with the door shut. Im sure you wont get the skirts on properly without taking the a4 sill trims off and cutting them. I took mine off and still havent got round to fitting them back on yet.
  5. floyd 1.8 turbo
    632
    Ok cool, Thanks. I'll prob just take them off and leave them off. Are there any holes etc under the trims?...if the shuts underneath are ok i'll butcher them off and chuck them
  6. ian52
    1,199
    Try and be gentle and get them off whole so you can trim them and put them Bach on. It don't look right without it. Did you get the front and rear brackets with the skirts?
  7. floyd 1.8 turbo
    632
    Errr dont know, where it bolts onto the front and rear wings?
  8. jcb
    jcb Active Member VCDS Map User
    4,132
    13
    my sill trim needed a strip cut off them to go back on top of the S4 ones
  9. floyd 1.8 turbo
    632
    Got the trim off, how much double sided was holding them on!! The skirts fit much better now. All i need now is the bracket that goes on the rear of the sill for the skirt to bolt on to, any one have one????
  10. Broken Byzan
    13,235
    464
    I had to get mine from Audi as they are welded to the sill.
    I didnt weld the new one on, i used wing screws and sikaflex, that bad boy aint going anywhere,lol
  11. mckay9uk
    mckay9uk A4 2.4 30V PES Supercharged
    158
    If you get the brackets can you post the part no's please. Thanks
  12. Broken Byzan
    13,235
    464
    Etka says they are.
    L rear 8D0 854 977 and the right hand saide one is 8D0 854 978.
  13. ian52
    1,199
    I didnt get the metal brackets just the plastic one that goes into the arch and the skirt screws into that and then some of the fastners that go into the floor of the car.
  14. floyd 1.8 turbo
    632
    I'll just make up some L shape brackets and weld them on the sills, be quicker and cheaper than ordering some from audis.
