S4 seats
951 Sep 26, 2007
  1. 951
    951 Member
    530
    I wanting to fit some s4 recaro's in my car ,they are from a facelift model and mines a pre facelift model with recaro's already fitted. Will these fit straight in ??. I did read on the forum that the airbag conectors will be different so how easy is it to get round it ??
  2. Broken Byzan
    13,244
    468
    Its just the airbag connectors that are different. You could bridge your connectors with a 5 ohm resistor to put the lights out. The seat airbags obviously will not work,but the rest of the system will.
  3. 951
    951 Member
    530
    Is there a way of getting the airbags conected as if i leave then disconected im bound to need them !!!
  4. docurley
    4,073
    88
    None, the best you can do it switch the light out.
  5. Blue_Thunder
    Blue_Thunder Well-Known Member
    1,778
    33
    I don't think a 5 ohm resistor will do it. I've got a bunch of resistors from when I did mine as I had to buy 20 of them! Give me a shout if you need a couple.
    Are your Recaros OEM? I thought the Audi Recaros only came fitted to Facelifts.
  6. Broken Byzan
    13,244
    468
    Maybe it wasnt quite 5. maybe 4. summat. Anyway you get the idea. lol
  7. 951
    951 Member
    530
    I was told they were recaro's when i bought the car but they might not be. They are the sports seats and as far as i know they are the original ones. If i can get the airbags to work i dont think i'll bother changing the seats though !!
  8. jase0851
    jase0851 Member
    789
    if the seats dont have recaro stamped on them then they arnt recaro,s people call any seat with a bit of extra bolstering recaro,s which is not correct. as for the airbags, i managed to fit a 2004 s4 interior with front seat airbags in my b5 and a 2004 steering wheel/airbag all i did was change the connectors for the new type no probs at all
  9. 951
    951 Member
    530
    The seats i want to fit are the s4 cloth type which are identical shape to the one already fitted so wont be recaro's either. Will this mean the conectors will be the same ??
  10. docurley
    4,073
    88
    Yes but you must have a face lift car if I'm correct?
  11. jase0851
    jase0851 Member
    789
    yeah it was a facelift b5 doc
