s4 rear brake calipers
batty Jun 2, 2008
  1. batty
    batty Member
    59
    anyone know the best place to buy a pair of these?
    Audi dealer is rather pricey..!!
    GSF don't stock them.
    any other ideas ?
  2. docurley
    4,073
    88
    Try over on RS246.com they seem to pop up over there a lot or just upgrade to the RS4 units if a full set-up pops up ore post a WTB add and someone will get back to you.
  3. Blue_Thunder
    Blue_Thunder Well-Known Member
    1,778
    33
    I chucked a set of mine away. Discs and pads had only done a couple of thousand miles as well. Didn't realise they'd fit any of the A4's.
    D'oh!
  4. docurley
    4,073
    88
    straight bolt on with disc and lines
  5. PaulJC84
    PaulJC84 Owner
    2,922
    17
    What size are the B5 S4 rears?
    I will need some new rear discs and pads soon and was thinking of doing the B7 S4 rear with the 034 bits.
  6. docurley
    4,073
    88
    I would go with the RS4 B5 rear much cheaper to buy and the pad are around £25 on ebay for Mintex's
  7. PaulJC84
    PaulJC84 Owner
    2,922
    17
    Yeah what size are the discs they use? What would I need, caliper, disc, pad, lines? No adapter for the B5 RS4?
  8. jcb
    jcb Active Member
    4,132
    13
    even if you didn't want them...you didn't think of eBay?
  9. Blue_Thunder
    1,778
    33
    Yes, but new discs are over £400!!!
  10. docurley
    4,073
    88
    who said new!!!
  11. PaulJC84
    PaulJC84 Owner
    2,922
    17
    For the rears?
  12. docurley
    4,073
    88
    I would post up on RS246.com stating what your after as for size im not sure I'm trying to find out.
  13. PaulJC84
    PaulJC84 Owner
    2,922
    17
    Yeah I think I will look into it soon.
    So just to clarify they bolt on directly? Just need different lines? Would I need custom lines or just the RS4 ones
  14. docurley
    4,073
    88
    you need calipers, disc, carriers, lines and pad oh and water refector sheilds.
    Also ZeroK66 just bought a set of rear brakes for his S4 so he will be selling his so chuck him and email http://audisrs.com/ftopic293-0-asc-15.php he's also a member on here under the same user id.
  15. docurley
    4,073
    88
  16. jcb
    jcb Active Member
    4,132
    13
    i got B5 front discs, calipers with hoses, rear discs (almost new), rear pads, hoses for £300 from dhali on RS246.
    sold the fronts discs and calipers (no hoses) for £200.
    saw some b5 front calipers go for £41 on eBay. wish I had bought them
  17. PaulJC84
    PaulJC84 Owner
    2,922
    17
    Cheers mate, I wonder what the deal is with this new forum.
    It will just mean RS246 guys will have to post there stuff twice.
  18. docurley
    4,073
    88
    LOL, sound about right I have already seen a couple from one forum on the other.
  19. jcb
    jcb Active Member
    4,132
    13
    its funny, seen a bit of banter between the two...very petty if you ask me.
    just means I waste more time when I should be working!
  20. aragorn
    18,657
    875
    probably worth pointing out that the s4 rears will only fit quattro a4's, the FWD's have the hub and bearings integrated into the disk itself, quattros have a seperate hub and disk as does the s4.
    The later cars (B6 >) all have the seperate disk and hub regardless of it being FWD or quattro so theres no upgrade path for FWD there either.
  21. batty
    batty Member
    59
    the best option i've found for rear calipers - std S4 B5 - is to have them refurbished.
    mine has a split boot and a sticking piston. they also need painting.
    i looked at www.biggred.co.uk and gave them a bell. they didn't have any spare calipers, but could refurb mine with a heat resistant black paint for 160 gbp plus post.
    for that money they'll be better than new. new price is 135 each.
    i thought about a pair of used parts, but the chances are they'll need painting and poss refurb soon.
  22. PaulJC84
    PaulJC84 Owner
    2,922
    17
    Anyone know roughly how much the RS4 bits should cost minus say the discs and pads?
