S4 offset on a A4 tdi?
choimaloy Jan 12, 2012
  1. choimaloy
    choimaloy Member
    111
    I've got some Avus s4 alloys on my A4 tdi,they have an et45 so what spacers would you recommend to get the wheels to fill the arches as they won't sit out as far as the do on an s4.
  2. AudiLeon
    AudiLeon Well-Known Member VCDS Map User
    2,169
    148
    If they're ET45 on an S4 they're ET45 on yours. They'll stick out as far. If the S4 has wider arch then they'll already stick out further on yours.
    I'd stick 10mm spacers on that and be happy.
  3. xs2man
    xs2man Member
    790
    As far as I'm aware there is no difference between the S4 and any other B6. So the wheels will sit just the same. That being said, if you want to fit spacers, 5mm on the front and 10mm on the back will set it off perfectly.
    rawtor51 likes this.
  4. choimaloy
    choimaloy Member
    111
    I thought the discs were wider on an s4 so the wheels sat further out.
  5. quattrojames
    14,046
    570
    I've heard that mentioned, but never seen any proof of it.
    As said, 10mm spacers will be ideal.
  6. AudiLeon
    2,169
    148
    The difference in disk would be tiny. 1mm maybe? I can measure my old ones if anyone wants.
  7. choimaloy
    choimaloy Member
    111
    So what make of spacer and how much atelier lookin at,I've seen the usual on eBay are they any good.
  8. BahnStormer77
    BahnStormer77 BahnStormer
    2,754
    53
    My S4 Avus wheels look pretty sweet on on my B6 without any spacer.... you could probably get away with 5mm-10mm if you REALLY wanted them further out.
    PErsonally I'd only consider hubcentrics, so that means 10mm at least and I think the stance is fine as-is.
  9. quattrojames
    14,046
    570
    I bought H&R from DPM Performance, they're not the cheapest, but who wants cheap spacers.
