S4 losing boost
s4mark Jun 17, 2007
  1. s4mark
    s4mark Member
    294
    10
    Hello everybody.
    My S4 is poorly. I posted a few weeks ago saying that I thought one of my DV valves was dead due to the noise it was making when coming off the throttle.
    It now seems to be struggling to boost past 3000 rpm and the noise from the DV (or other air leak) is getting louder.
    It is booked in next Saturday at MRC in Banbury for a health check so the car covers going on and the keys are getting put away until then.
    Do you think it will be ok tho drive it up there carefully? Its all motorway for me so could stick it in 6th and just drive it up extremely carefully or do I stick it on the back of a truck?
  2. GSB1
    GSB1 Member
    283
    Call them and see what they say. I think there is something you can disconnect so it won't attempt to boost past a very low pressure, may help preserve things.
  3. Dan Gliballs
    Dan Gliballs Active Member
    1,568
    Driving up there off-boost should be fine,.................don't QUOTE me on that though lol
    Yeah, as said, make the phonecall before you take the risk :)
  4. cliveh
    cliveh quattro in the bones
    30
    Yea, give Doug a call, but I would agree with the above, and the ECU will normally deliver only "safe" levels of boost under certain conditions.
    But the DVs do not have sensors, so unless their ineffective operation results in something else down the line sensing a problem, this is not guaranteed. Easiest job to be sure is to disconnect the MAF.
  5. shineydave
    shineydave Member
    920
    IIRC you can disconnect the EGT's, that should limit the amount of boost to 0.3bar so even if you do put your foot down you shouldn't create enough boost to do any damage.
    obviously though as stated above, just take it nice and steady, i've no doubt there's loads of people driving around at the moment with knackered DV's but since they're not thrashing them they don't do any damage
  6. cliveh
    30
    Yea, that would be a safer option, Dave:icon_thumright:
  7. shineydave
    shineydave Member
    920
    lol, only problem is i can't remember where the plugs terminate and i'm at my brothers now and my car is at home so i can't look
  8. Blue_Thunder
    Blue_Thunder Well-Known Member
    1,769
    31
    It's not the EGT's, it's the N75 valve you need to disconnect. I had a serious boost leak on mine and Doug diconnected mine so that I could drive it the 150 miiles back to my garage so they could finish the job off properly! It means the wastegate actuators are left fully open by the ECU so that most of the exhaust gas bypasses the turbine, therefore reducing the amount of boost (and more importantly, turbo speed).
    Would still recommend you try and drive off boost. A motorway journey should be ok with your N75 disconnected. It's stopping and starting at traffic lights that will cause you the most trouble.
  9. satans child
    satans child project...satans child
    141
    egt's and disconect your n75:wtf:
    just disconect your maf plug and you wont see more than .5 bar
  10. jcb
    jcb Active Member VCDS Map User
    4,132
    13
    get a trailer.....
  11. GSB1
    GSB1 Member
    283
    Are you saying disconnecting the N75 will not help Satans_child?
    0.5 bar isn't really miles below stock boost anyway is it?
    Rather than be so critical of others advice, perhaps expand a little yourslef if you can help.
  12. satans child
    141
    no im not...
    but i wouldn't want to explain witch one there looking to unplug as most dont know these cars at all..
    and if im right it wouldn't be any different to unpluging the maf??
    i could be wrong please correct me ?
    im sure you will:nyah:
    im not being critical just realistic..
  13. Olly_K
    Olly_K Administrator
    2,678
    unplugging the MAF wont help, I used to drive my RS4 with it disconnected due to a faulty MAF and it ran better.
    disconnecting the N75 is dodgey, but probably a better option, the best being a trailer
