S4 going into safe mode...
keith89 Jun 28, 2012
  1. keith89
    keith89 New Member
    I have a 2004 S4 when you put the key in the on position the insrument cluster says safe were the mileage should be And will start for a second or two and cut out is there any easy way to sort this ?
    Thanks in advance
    Keith
  2. kite
    kite Member VCDS Map User
    677
    Immobilization blocked.
    Scan the car for faults.
    Have you dropped your key?
  3. edirance
    edirance New Member
    14
    have got same issue can anybody say something abt this problem... mine is audi a3 2.0 fsi 04reg..
  4. Dubbers1
    Dubbers1 Top Gear VCDS Map User
    270
    67
    Get it scanned with VCDS, where are you from?
    Someone should be able to help, check the VCDS Users Map in the VCDS section
