S4 exhaust question
s4mark Jun 14, 2013
  1. s4mark
    s4mark Member
    294
    10
    Hi all, well had the s4 for a few months now and still so pleased however I have noticed that the left exhaust pipe gets very black and sooty quickly where as the right hand one seems to stay pretty clean. Anyone have any idea why this might be happening? Does one do more work than the other or may it indicate that a sensor has gone bad causing it? I plan to get it down to the specialist I use when i get a chance and no doubt they will stick it on vag com but just thought I would see if any one else has had this issue.
    Other than a slightly noisy fuel pump, I cant really fault it, car seems to run fine and check oil level religiously every week. Any ideas appreciated.
  2. colinurquhart
    colinurquhart Member
    203
    34
    The two exhausts are completely independent but my left one soots up quicker than the right also but it's never really bothered me too much. It will be interesting to hear what your specialist says so I'll keep an eye on this thread.
  3. dualmono21
    dualmono21 Well-Known Member VCDS Map User
    1,132
    tiptronic or manual ?
    the tiptronic exhaust has valves in it which open at a certain rpm if one of the valves is stuck then this could be the problem
  4. Paul @ Unit 9 Remaps
    Paul @ Unit 9 Remaps Site Sponsor Site Sponsor
    2,035
    131
    Maybe an Injector' Possibly EGR could be a few things maybe sooted up CAT theres a few possibilitys it could be
  5. colinurquhart
    203
    34
    They all have the exhaust valve on the back box.
  6. s4mark
    s4mark Member
    294
    10
    its a manual
  7. colinurquhart
    203
    34
    Also I doubt the valves would be the issue as I've just changed my exhaust and now have no valves and still my right pipe soots up quicker.
  8. dualmono21
    1,132
    not seen a manual mate
    so didnt want to assume they were the same or indeed differant
    ive also changed my exhaust but both exhausts seem to soot up around the same
  9. GeoffDunk
    GeoffDunk Well-Known Member Team Panther Audi RS4 quattro Audi Avant Owner Group
    1,301
    388
    I recently had my valves serviced and checked for operation as one side sounded louder at idle than the other and sure enough there was one stuck open, both now operating correctly and still the left hand tail pipe soots up a lot more than the right.
    Mine is also a manual and I had never really thought anything of it but would be intrigued to find out why this happens, seems common though.
  10. deano1978
    deano1978 different gear
    713
    80
    Same with mine too. I put down to the way the pipes divide. If you have a Y shape splitter then it should split evenly. But mine is a straight through then branches off to the right.
    If you think of it like a long straight water slide,but then add a slide on the side,majority of water will still flow down the main slide,but some will flow down the side too. Just not as much.
    Thats my theory anyway :)
  11. GeoffDunk
    1,301
    388
    The S4's V8 exhaust doesn't split or intersect for that matter, individual pipes front to back, no Y-splitter.
  12. s4mark
    s4mark Member
    294
    10
    at least it seems a common issue so that makes me happier. Once its been down for its health check i will post to let you all know what they say
  13. deano1978
    713
    80
    :O
  14. Paul @ Unit 9 Remaps
    2,035
    131
    Same for the 3.0 V6 also
