S4 ENGINE AND TRANNY WEIGHT ??
andybnwc Feb 25, 2010
  1. andybnwc
    andybnwc Member
    752
    been searching about for the answer so i can get a crane ordered just want to check a 1 ton one is ok for the job?
  2. jcb
    jcb Active Member VCDS Map User
    4,132
    13
    well under 1 ton
  3. aragorn
    18,300
    805
    The engine is probably 210kgs or so
    The box is maybe 50-75kgs?
  4. jcb
    4,132
    13
    Well I know first hand that a 1.8t block, head, flywheel, clutch and engine stand adapter is about 0.1kg short of "too ******* heavy"!!!
    nearly burst a testicle getting it on the engine stand!
    I was feeling young and ambitious at the time!
  5. B5NUT
    B5NUT Well-Known Member VCDS Map User quattro Audi A6 Audi Avant Owner Group S-line owners group
    3,725
    650
    Fantastic :laugh:
    I was also looking for a crane to remove a 1.8 engine so if the S4 is under then ton then it should be fine for the 1.8...
  6. Broken Byzan
    13,237
    465
    The box is deffo heavier than a 5 speed by about 20KG.
    And to move an s4 lump arond a garage floor took 4 of us,lol
    You could cut the whole front off the car and lift it for under a ton. I am sure the crane we hired was a ton and it p!ssed it
  7. jcb
    4,132
    13
    not many engine/boxes break the 350-400kg mark
  8. ian52
    ian52 2000 a4 1.8tqs-yellow
    1,199
    I bet a few yank boat anchor v8's will.
  9. jcb
    4,132
    13
    actually a lot of the yank boat anchors were much further ahead in using aluminium blocks/heads. its one of the reasons Rover bought the rights the Buick V8 that filled the Land Rovers, Range Rovers, SD1's, MGBs, Triumph Stags, TVR's etc etc.
    they may be push rod tastic old school **** now but remarkably light....
  10. ian52
    1,199
    Pitty they dont make the cars lighter then.
  11. jcb
    4,132
    13
    true...pity they don't make some yanks lighter too! :)
  12. andybnwc
    andybnwc Member
    752
    Okee Dokee 1 ton crane it is then , i shall probably be renting this out after ive bought it too
