S4 Cambelt, tensioners, water pump etc
Nez Feb 19, 2009
  1. Nez
    Nez Member
    598
    Hi all :)
    Just went to a specialist dealer not too far from me and they quoted approx £350 for Cambelt, tensioners, water pump etc .
    Are these prices normal for independent specialists or over the top? The garage said labour would be in the range of £180-£200 (out of the £350)
  2. GSB1
    GSB1 Member
    283
    An absolute bargain so long as the parts list isn't skimped on (no point given the labour to parts ration) and you can trust them to get the timing right etc.
    Add any parts that fall short of the recommended cambelt kit for an S5 and bite their hand off!
  3. That sounds too cheap to me. Isnt the water pump alone 50 quid? Plus the belts and tensioners kit which is 200 or so? I may be wrong on the belts/tensioners cost though.
    It's approx 5 hours labour, so work out the labour cost based on that.
  4. Blue_Thunder
    Blue_Thunder Well-Known Member
    1,776
    33
    And don't forget to change the thermostat!
  5. aragorn
    18,612
    872
    200quid for 5 hours work seems fair to me?
    The £150 for the rest of the parts does seem a bit tight:
    I'd imagine about 25-35 quid for the waterpump, a quick check online shows the timing belt kit is around £165+vat:
    https://sslrelay.com/buypartsby.co.uk/timing-belt-kit-info.php?recordID=588
    Perhaps it will be a little less with trade discount but a lot of these online places are selling at near enough trade prices anyway.
    As long as the belt AND tensioners are done, along with the waterpump you should be fine. As has been said, get the thermostat changed while your in there, and it might be an idea to do the serpentine belt and its tensioner too while its off.
  6. Fraser
    Fraser Member
    584
    worth doing the auxiliary belt and a few of the others too - they are super cheap
  7. Nez
    Nez Member
    598
    They parts they will change as fews:
    1) Timing Belt
    2) Water Pump with Gasket
    3) Serpentine Belt
    4) Idler roller
    5) Tensioner roller
    6) Thermostat with O-Ring
    All this for £350 :yahoo: will book this for next week and the garage is very good as my brother in law changed his A4 1.9 TDI timing belt there and he is very happy with their job and he paid £180 :uhm:
  8. aragorn
    18,612
    872
    Sounds like a very good price.
    I presume the idler and tensioner mentioned is the timing belt ones?
  9. stapo69
    stapo69 All hail the mighty quattro!
    969
    That's an excellent price, took me a whole day to do this, Audi would charge near a grand for that! Agree the price for definate before they do the work. Bargain!
  10. Nez
    Nez Member
    598
    Yea its for the timing belt :)
