S4 Brakes
Markey Apr 20, 2005
  1. Markey
    Markey Active Member
    2,175
    Anyone thought of doing this mod, is it worth it when running a Big Turbo, or will the TT calipers and A6 Disks be enough?
  2. RichA3Turbo
    RichA3Turbo ...Watching you! Moderator
    5,089
    [ QUOTE ]
    [/ QUOTE ]
    If it comes standard on any car other than RS4/6 then its not enough! Believe me at teh speeds you will get to without even realising it, even big brakes can sometimes only just be enough!
  3. Markey
    2,175
    LOL maybe a parachute as well then.
    Other big brake upgrade it is then maybe now im thinking of getting a big turbo i guess the TT A6 combo is not going to be good enough.
  4. Markey
    2,175
    What one of the Porsche kits are you using then Rich?
  5. RichA3Turbo
    5,089
    [ QUOTE ]
    [/ QUOTE ]
    ECS Stage 2v2 at the moment...
  6. imported_Cali
    imported_Cali Guest
    What conversion is it ?
    S4 set up on to A4 ?
    I have had a re-map and looking into the 312mm upgrade - don't want to go for anything non-audi.
  7. imported_Yaseen
    imported_Yaseen Guest
    s4 discs will needs the arms etc as well so don`t think worth the hassle.
    Im fitting A6 312mm discs but with Boxter callipers.
    Markey- If Rich with his power needs the boxter s callipers then probably best for you to get same-especially if your gonna track the car.
    apart from ECS also look at Bira for brackets or get used 996 callipers with s4 size disks as you can pickup the brackets seperately from Evoms/Bira.
  8. Markey
    2,175
    Cheers, im actually looking into Stoptech at the moment as they are properly designed to work with all the ABS and Bias stuff.
    There is an article where they tested all the brake kits Brembo the Porsche conversions and Stoptech came out on top.
  9. imported_Cali
    imported_Cali Guest
    [ QUOTE ]
    [/ QUOTE ]
    Will the S4 discs and calipers swap straight over on to an A4 quattro turbo.
