S4 brakes fitted on to A4 TDI
Caesium Apr 6, 2007
  1. Caesium
    Caesium My BM is fixed! VCDS Map User
    4,879
    Here we go!
    [​IMG][​IMG][​IMG][​IMG][​IMG]
  2. james0808
    james0808 Active Member
    3,548
    WOW,what a difference.
  3. Caesium
    4,879
    Even more WOW when I hit the brakes.....
  4. Rev-head
    Rev-head Active Member
    2,987
    did you have to mod carriers?
  5. Caesium
    4,879
    Nope! just bolt straight on
  6. james0808
    3,548
    Told you they would.And you wanted 312mm:no:
  7. Caesium
    4,879
    ok ok....
  8. james0808
    3,548
    It just surprises me how many people waste the money on 312mm when you can get much better for less.
    Glad you got them sorted and they look fantastic.:icon_thumright:
  9. 46TheDoctor
    46TheDoctor Valentino Rossi A.K.A The Doctor
    312
    What year S4 do i need the bits off then please?:hubbahubba:
  10. james0808
    3,548
    B5 and B6 S4 will fit.
    B5 are 321mm i think with twin piston calipers.These fetch £120 with average condition discs and pads,
    The B6 are 345mm discs with single piston caliper.Harder to find and more expensive £200 is a good price ive seen these fetch £300.
    This is the B5
  11. Caesium
    4,879
    This is the B6
    To fit these onto my car I had to order 2 brake pipes, brackets and bolts from Audi. They are going to be about a week.
  12. james0808
    3,548
    What pipes?Brackets?
    How much was they?
  13. Caesium
    4,879
    2 pre formed copper pipes from the caliper union to the flexible hose, one either side, they attach to a bracket that's bolted to the caliper, this bracket also holds the ABS and pad wear wiring.
  14. james0808
    3,548
    I got all the pipes with mine.Didnt realise they was different.
  15. bubstar
    bubstar Member
    550
    Good work! I'm just about to fit the B6/7 S4 fronts to my S-Line (312mm). I've had some Goodridge hoses made too.
    How do you find them?
    BUB :beerchug:
