S4 (B6) Engine Speed Sensor location
lincoln_dj Apr 16, 2013
  1. lincoln_dj
    lincoln_dj Active Member VCDS Map User
    469
    61
    Quick one guys,
    Can someone please tell me where the engine speed sensor is on these 4.2 lumps? Have looked around and only found guides relating to other engines (eg B6 A4 1.8T: Engine Speed Sensor (G28) Replacement).
    Don't want to be undoing the wrong one (crank position etc)!!!
    Cheers,
    Adam
  2. lincoln_dj
    469
    61
    hi again,
    i got hold of elsawin thinking it would show me the location, but i cant find it! anyone know where it's located please? or will it be pretty obvious if i get the car on some ramps?
    cheers
  3. ricostuart
    ricostuart Active Member
    409
    43
    would be interested to know this myself. Aint got a clue myself im afraid
  4. quattrojames
    14,068
    585
  5. dualmono21
    dualmono21 Well-Known Member VCDS Map User
    1,138
    the vehicle speed sensor is on the front axle behind the back of the brake disc
    pretty sure its the passenger side
    just trying to find the engine speed sensor now
  6. lincoln_dj
    469
    61
  7. dualmono21
    1,138
    white/grey connector on the firewall just behind the coolant reservoir
    trace it down with your hands
    its a ***** to get too ... in some cases it might even be worth removing the catalytic convertor on that bank for ease of access
    do you have a manual or a tip ??? theres even less room with a tip , but you can lower the gearbox subframe down to gain better access
