S4 avant towing weight help wanted
OllyS4 Apr 15, 2008
  1. OllyS4
    OllyS4 Member
    143
    Could some please confirm this for me.
    I don't have a hand book and the sticker in the boot is missing.
    The car is a 1999 S4 avant 2.7 biturbo
    I would like to know the tow weight, ball weight and the car weight and any other info you think i might need to know about the car when towing.
    Olly
  2. Blue_Thunder
    Blue_Thunder Well-Known Member
    1,778
    33
    Don't attempt any traffic light races.
  3. AndyMac
    AndyMac Moderator Moderator
    9,832
    46
  4. OllyS4
    OllyS4 Member
    143
    If i read it rite it is braked trailer 1800kg and unbraked trailer is 750kg.
    Could any one confirm this from there hand book?
  5. jcb
    jcb Active Member
    4,132
    13
    tip:don't forget the trailer is there and take any sharp corners!
  6. farmerq
    farmerq New Member
    i don't have an s4 but can confirm the max weight for any unbraked trailer regardless of what is in front of it is 750kg
  7. Nessy
    Nessy VW + Audi mad
    973
    97
    If its any help I've retro-fitted a Genuine Accessory Votex detachable towhitch to my Avant (its a Westfalia item and is identical to the factory-fitted detachable towbar option) and the fitting instructions state
    "the tested drawbar ratio is 10.1kN.This equals for example, a trailer load of 1800kg and a permissable weight of 2400kg"....
    I've no idea what the 2400kg figure is all about though, I've always understood the limit to be 1800..........
    The ballweight is 75kg.
  8. OnTheJazz
    OnTheJazz Member
    37
    i'll have a look in my manual, but i have towed 2000kg with my TDI avant and would not recommend it!:wacko:
  9. OllyS4
    OllyS4 Member
    143
    Thanks everyone. I hope to tow a mk2 golf (964kg had it weighed) on a light weight car tailer 130kg so should be well in and under the 85% rule.
  10. smitch
    smitch Active Member
    1,588
    The legality is that you cannot exceed the manufacturers towing limit. Unfortunately in most cases this is greater than the unladen weight of the car and people tow up to it not realising this is unsafe if you are inexperienced.
    The 85% rule is best kept to as if the trailer exceeds the weight of the towcar and you got into trouble it could turn in to a case of the tail wagging the dog.
    If you are experienced at towing and drive sensibly it is possible to tow more than the car weighs safely assuming that this is in line with the car manufacturers towing limits.
    I sold caravans for ten years and used to tow everyday and have regularly towed large caravans that outweighed the tow vehicle for great distances and never had any trouble what so ever.
