S4 AVANT 2000 BUYING ADVISE
wayne77 Jul 15, 2009
  1. wayne77
    wayne77 Member
    76
    hi guys im going to look at an s4 avant on saturday with a view to buying its done 80000 miles with fsh can anyone please give me any advise what to look for in terms of common faults or turbo problems,suspension etc etc ant help would be great
    cheers wayne
  2. jcb
    jcb Active Member VCDS Map User
    4,132
    13
    My 2p
    Engine:
    make sure it is startng from cold when you start it- look for blue smoke from start up.
    any unusual whines or whistles (or worse case scratching scraping) immediately at start up or idle - shagged turbos/seals/boost leak
    suspension
    knocks clunks and general vagueness on steering and or bumps - suspension arms ball joints and bushes
    droning from any wheel or rear - wheel bearings/rear diff
    rear clunking when power put down- rear diff mount bush
    clunking when dumping clutch - engine mounts/trans mounts (poss Dual mass flywheel but that will be nosiy throughout if properly shagged)
    usual stuff you would look for. timing belt change recently.
    brake condition, tyre condition, wheel condition, stone chips, any overspray, panel gaps
    would have a butchers on RS246 in the 5 S4 forum as I think they have a detailed buyers guide
