S4 ARB or RS4 ARB?
DALE_AVANT Mar 20, 2013
  1. DALE_AVANT
    DALE_AVANT Member Audi A4 Audi A3 Audi Avant Owner Group Team Brilliant Black TDi
    612
    19
    In relation to fitting to a TDI 130 Avant Sport, which would you folk recommend?
    Do both the S4 and RS4 need new brackets, and can you get these with the bar?
  2. KevM3
    KevM3 Member
    102
    use the old brkts ,just need new bushes , get an rs4 arb , much better !
  3. dpbayly
    dpbayly Member
    391
    Fitted the RS4 to my Avant a month or so back, top mod.
    I wouldn't even consider the S4 one over the RS4 It's not as if the RS4 one is expensive,
    go for it, it makes a very noticeable difference to the handling.
  4. jdp1962
    jdp1962 Grumpy Old Moderator Staff Member Moderator Team V6 TFSI Owners Group Gold Supporter Team Tornado Audi S4 quattro Black Edition s tronic
    8,097
    2,549
    RS4 rear anti-roll bar, all the way. Works a treat on B6 and B7 models, especially the V6s.
  5. DALE_AVANT
    612
    19
    Does it increase the work that the rear tyres and suspension have to do?
  6. robotplant
    robotplant Member
    154
    If your going to make the most of the better handling you will have with the RS4 arb then sure you will be giving your tyres especially a harder time as for the suspension...not really. Use your old drop links unless they are showing signs of wear, you will need new brackets and bushes due to the increase in diameter. Worth all the effort.
  7. DALE_AVANT
    612
    19
    Good info guys.
    Do the S4 and RS4 have seperate brackets?
  8. adamss24
    adamss24 Well-Known Member
    4,558
    394
    The overall size of the brackets is the same between the diesel, s or rs models ! it's the internal diameter of the bush that's different and as above rs4 all the way ! I have it on a FWD 1.9 tdi which crapped it's gearbox after a big power hike, it made it handle really like a quattro in the dry ! Still no substitute for the quattro in the wet !
  9. DALE_AVANT
    612
    19
    The sport models have very little body roll anyway, I still get the feeling that the 22mm bar would be too stiff
  10. robotplant
    robotplant Member
    154
    NO and double no, the quattro sport has some body roll with the RS4 arb fitted the balance between stiffness and roll is perfect, you turn into corners with added confidence. Try it if you don't like it there will be plenty of takers on this forum alone who would buy it off you, but I bet you won't sell it!
  11. AlexGSi2000
    AlexGSi2000 Well-Known Member VCDS Map User
    1,464
    199
    Do it - I fitted my RS4 ARB along with coilovers and new front suspension arms - will never look back. Handles great for an estate!
  12. dualmono21
    dualmono21 Well-Known Member VCDS Map User
    1,132
    i changed mine on my s4
    gave me better turn in as a result which was good , but on the downside it doesnt change direction as fluidly as it did before
    make the anti roll bar too stiff for the rest of the car and there will be consequences
  13. Mike.M
    Mike.M Well-Known Member
    2,477
    169
    RS4 on my Sport and works a treat. Make sure you get the matching bushes and larger clamps with new bolts as my bolt were corroded badly.
  14. jdp1962
    8,097
    2,549
    Yes, but they still have lots of understeer, which the 22mm RS4 anti-roll bar will reduce considerably.
  15. DALE_AVANT
    612
    19
    Living in Milton Keynes, tyres get a harder time due to all the roundabouts, hence I am still erring towards the S4 bar to allow for this
  16. Andie0
    Andie0 Member
    490
    13
    Can i ask off what year rs4 do i need to get for my b6? I wont to do this mod right as have been putting it off but am readu to buy and am going to tps this week want to get it all thanks
  17. dualmono21
    1,132
    it needs to be from the b7 andieo
    the mod increases turn in , but as a consequence reduces rear grip coming out of the corners
  18. Andie0
    Andie0 Member
    490
    13
    Thanks mate i will be getting one! Well i best not do any lift off oversteer coming out the corners then ai lol
