s4 air bag light.
Kush
netherley
Hi people,
Im having some bother with my b5 s4 air bag light well its been reset and after a few miles its back on why?
I have changed the male and female connectors under the drivers seat but no diffrence after a reset so was thinking can i delete the connectors and just join the wires?
Or advice would be perfect....
You need to find out WHY its on, rather than just resetting it.
A proper vagcom scan will tell you.
If its the drivers seat airbag then as you've suggested you can solder the wires together.
I'm having a similar problem, and Vag-Com is giving me the 65535 (Controller Malfunction) code, and when connected , the Module reports the part number as starting with 8@0 as opposed to 8D0! It then reports an error when you clear the DTC. The e-bay code clearer works, but if the outside temp is low, it comes back on - and in Aberdeenshire, it is ALWAYS low!
22
3K
12
932
824
12
4K
