s3gazz's slow engine build
s3gazz Aug 30, 2012
  1. slowcoach3
    slowcoach3 Active Member
    820
    103
    43
    I think everyone is pretty stoked for Gaz to have got those figures, after all he has put feckin bucket loads of time, energy, enthusiasm and not a little bit of cash into his build. There is clearly something slightly amiss though, would it be better to say nothing at all and let Gaz run around with a car that's got a problem for the sake of not risking offending anyone?
    Don't think most people care who mapped it but when a slightly freaky result turns up and there are some data inconsistencies and a dodgy looking actuator people are always going to ask a question. Don't think it matters where its mapped for those questions to be asked either. Big up to Gaz for an awesome build no one is trying to take anything away from him.
    m19lte, s3gazz and Andrew@A.L.D like this.
  2. Broken Byzan
    13,235
    464
    I'm sorry but neither I nor gaz see them as negative comments. I felt they were questions aimed at helping him get to his goal. Ie ride height issues will be the same whatever dyno and whatever tuner he chose hence the question. Fyi rick does play that game just not in here... ;-) . All comments thus far are based upon what gaz has said and I can see people just try ing yi help. Any more off topic and it will have to he dealt with accordingly. :-D
    m19lte likes this.
  3. superkarl
    superkarl MAN OF STEEL
    9,326
    2,329
    I am also glad rick doesnt bother with the disrespect on forums and its for that very reason he is my number 1 choice.
    EDITED: so as not to contribute to this childish discrediting of tuners.
    m19lte, ScottD3 and s3gazz like this.
  4. s3gazz
    s3gazz Well-Known Member
    1,376
    99
    Ok ok moving on guys.
    BIll as my car stands the front wheels are almost under the side panels lol niki said to me it has to be standered high to go on his dyno pal and was only going to take it there as no one believes rick has mapped it to the figures he got from my car and what on the dyno print out.
    this is how it's gone I bought a maf from ECP and never tested g/s now I have there low getting a new one today see if any different.
    I had no preload on my actuater and so I unplugged the n75 and tried the car only getting 6 psi so I then added preload and now all gravy but somewhere from been mapped to getting home somate happened I don't have a clue what.
    the actuater at the min I carnt add anymore pre load at all my change to a 15psi actuater if the wastgate is been blown open then the actuater is the problem and will all be solved plus a tweak for the tip been sealed.
    i will be going to r-teck to see what happens on nikis dyno and then all will be revealed to what my car makes after ricks great tuning no dyno the same so just to close all suspicions .
  5. beachbuggy
    beachbuggy Well-Known Member
    1,931
    201
    It is a 12psi actuator, always has been!.. It ran 11psi on n75 DC0 with Rick whilst he was mapping it. Which he was happy with..
    Then a some stage as I explained to Gaz the nut on the end possibly had come loose and the preload backed off and even more likely the wastegate open.. It wasn't boosting till gone 4500rpm which as I told Gaz many a time, ment the wastegate wasn't closed fully, probably due to the nut coming loose..
    Then when the nut was done back up as I asked the boost came back, and it was fine.. I can only think now it has been over preloaded if the screw thread has run out..
    It happen to Prawn, as he called me from the side of the motorway saying exactly the same thing many moons ago..
    I don't think a 15psi actuator will make any difference to Gaz as it's already at what I feel is the max of the setup.. But it is always good to test these things and maybe just maybe a little more can be gotten from this Turbo and setup..
    m19lte and s3gazz like this.
  6. s3gazz
    1,376
    99
    Thx dan.
    so ill undo the actuater then dan and see what happens but still from the airflow I'm getting carnt see 50bhp added that's why I'm still convinced the wastgate or actuater lol
  7. s3dave
    s3dave TFSI Hybrid Supporter
    10,110
    736
    Gaz i asked you yesterday figures aside, what it felt like on the road, you know real world, and you said "very strong and made you smile...."
    Surley thats all that matters, you dont have to prove anything ....:icon_thumright:
    Prawn on your comments about not believing it made that power, and your disection of it ,,,that is probably why you are in construction and not a tuner....:icon_thumright:
    m19lte likes this.
  8. superkarl
    9,326
    2,329
    Would the preload he has now added, the maximum he can get, be now robbing him of travel and flapper angle?
    So prob better to change for a stiffer one to begin with without the sacrifice of travel.
    There is a good document floating around from the head of development at borgwarner that states an optimum wastegate flapper angle of 50degrees for max flow.
    Not that gazz can set that now with the turbo on
  9. beachbuggy
    1,931
    201
    Lets talk facts.
    The car was initally mapped with a bad MAF, it only read 222grams.. No matter how much was put through it..
    A new Maf was ordered and fitted and it instantly went up to over 250grams at a flat 18psi.... It peaked if I remember correctly on the dyno at near 265grams
    The car was fully checked and tested before it was run, and it was running 11psi on actuator
    There were issues with the turbo Tip fitment, but this wasn't my fault, but the fact Gaz is actually running a chinese copy turbo that he asked me to make into a Hybrid, I did explain that I was a little wary but believed if it was done properly then it could be as good as an original. Gaz knew this, I knew this, and so the fact its made as much as the other hybrids just goes to show that you shouldn't always judge a book by its cover.
    I spent numerous hours on the phone to Rick whilst he was mapping it to get feedback etc. Mainly as I wanted, as I set out to do , to produce a non surging, good mid range hybrid turbo.. This , if the figures are to believed is exactly what has happened.
    I also spent many a hour texting with Gaz to get this actuator issue sorted... I was worried that as he had a copy turbine housing , and even though we had taken measures to stop the bush from moving, maybe just maybe that had happened again.. But no the actuator was at fault, either the loose nut or something else..
    I will say what is posted and what the actual events are, don't quite match up and thus un informed opinions are being made with out the full facts... and to this I think praise should go to Gaz and to Rick and Gaz should take the car to R-tech or Bills and get an independant Dyno run and then comparisons can be made in fairness...
    with out a little drama though, forums wont be worth reading.....:)
    m19lte and ScottD3 like this.
  10. Prawn
    11,354
    3,191
    Quite possibly Dave, but I think deep down, we all know I'm probably right....
    yes - how it feels on the road is the most important thing, but after god knows how long of ~200bhp, do we really think Gaz is going to feel the difference between 300 and 350? of course it'll feel fast as feck.
    Nobody is trying to shoot down the claims, but something really doesn't add up, air flow is poor, and it's pulling 7's on the timing.
    As for this clique, that one works both ways. From the other side of the fence, on which I'm quite obviously sat, it feels exactly the same. there seems to be some kind of anti-establishment clique, determined to jump on anyone offering constructive criticism and shoot it down as negative.
    Sure, everyones great, good luck to you. Who needs advice anyway? it's all on google....
    Gaz: the internet seems to tell me that I don't like you, although I'm not sure where it got that idea from. I hope you sort it mate, you bloody well deserve it.
  11. beachbuggy
    1,931
    201
    Simple answer to that. if the MAf is knackered then the Load value the ecu is seeing will be out and thus on the timing map which is Load V rpm will also be wrong, lower Maf reading = Lower Load calculation which will mean the wrong timing cell is used, which will be higher than it should be...
    s3dave likes this.
  12. superkarl
    9,326
    2,329
    ahhhhh, some clarity :)
  13. s3dave
    10,110
    736
    Really?...and there we have it....:happy:
  14. Broken Byzan
    13,235
    464
    No one doubt Rick tuned it, He is a great tuner, i am 100% sure he has, and reading through here i cannot see where anyone has stated he didn't tune it. I think it's the low maf reading v power we are all trying to get to the bottom of for you, so obviously questions get asked. I hope you can sus it, or perhaps rick will come on and say i scaled XYZ to make it work in closed loop or some such whichcraft
  15. Prawn
    11,354
    3,191
    I blame Scott, it was all a perfectly reasonable discussion before Scott got involved.
    It's usually a perfectly reasonable discussion Before Scott gets involved.
    A4/S4 forum(B5 Chassis)
    Just sayin....
  16. s3gazz
    1,376
    99
    Picking new maf up at 3am so ill go for a spin and see what happens might just be the maf I carnt say rick will get to the bottom of it no dowt.
    i just hope it's not the turbo copy
  17. Prawn
    11,354
    3,191
    Good luck mate. I hope it sorts things for you.
  18. s3gazz
    1,376
    99
    Me too prawn
  19. ScottD3
    ScottD3 I want your faulty electronics Supporter Team V6 quattro Audi A8 Team Akoya TDi saloon Audi S8
    15,161
    1,121
    Blame me all you what.
    But I'm not the only one who feels it. Maybe I'm the only one who's willing to stand up and ask the question why when no one else?
    I stand by what I said.
    I just wish others was willing to speak out and not just sit back and nod their head at the screen.
    Gaz, enjoy the car. You got nothing to prove to anyone.
  20. Rick @ Unicorn Motor Dev.
    Rick @ Unicorn Motor Dev. Site Sponsor Site Sponsor
    1,242
    578
    Hi all,
    Gaz just nudged me to have a look at this thread. The car was running a peak CF of 3 on 2 cylinders, 1.5 on the other two.
    Lambda approx 0.82, Peak injector duty cycle 89.5%
    If something has changed since I set it up then things are likely to be different.
    Regarding the power figure, I am quite suprised but there were no tricks involved. The dyno used is a Dastek setup in a a full dyno cell. It belongs to Ric Wood - some of you know who he is but for those that don't his credentials include building the engines for the top 228mph GTR's that broke the VMAX record. With the car running 12psi it made 290 on another dyno which is some kind of correlation.
    That said, dyno's are a lottery and I fully expect power to be different on a different day on a different dyno. I did not build the engine, port the head, spec the cams, or build the turbo. My job is to get the most out of the car whilst maintaining an acceptable level of reliability. What power the car then produces is largely out of my control.
    Thanks, Rick
    s3gazz, m19lte, jojo and 2 others like this.
  21. Broken Byzan
    13,235
    464
    From the horses mouth
  22. badger5
    9,317
    1,889
    I asked the question re the logs you asked me what to do on fb... and what you posted, indicates an under reading maf... given the boosts rick posted after mapping it pretty much look as logged on your logs of the weekend. The bit which does'nt correlate as right is the g/s readings, and as Dan has correctly said, will effect where the ecu thinks load is and run higher timing that it ought to (or mapped to originally)
    and some DATA to chew on - from logs off gaz compared to results rick posted as peak numbers from dyno when mapped.
    Dyno
  23. beachbuggy
    1,931
    201
    Wasn't it peaking at 26psi on the dyno? and 23 psi on the road, which explain the higher torque figures..
  24. badger5
    9,317
    1,889
    I read that also at the time....... 2550mb request in gaz's log.. so wayhay..
    hopefully the euro maf is the cause for more timing pull and low g/s
    keep hearing more and more folks suffering crappy euro mafs
    GSF ones I use, seem ok thus far
  25. beachbuggy
    1,931
    201
    Unless the same ecu fault that Gaz had before all this started has come back ;-) , then hopefully the MAF is at fault...
  26. badger5
    9,317
    1,889
    Good Good. I look fwd to reading the results.
    I'm sure Dan will be pleased when the results corroborated. K16/7+7 spec unit I think?
    Fingers crossed the ecp maf is the low g/s culprit
  27. quattrojames
    14,045
    570
    I'm sure you're all able to play nicely, any more reported posts emanating from this thread and I'll be testing out the 'Thread ban' option.
    Thank you.
    jojo and Kelza like this.
  28. s3gazz
    1,376
    99
    New maf on and just need to go for a spin or log it now before I go to rick Thursday
    Goubo1 likes this.
  29. Westy
    Westy Well-Known Member
    17,440
    1,097
    Stop typing and get driving :racer:
    ScottD3, s3gazz and Goubo1 like this.
  30. badger5
    9,317
    1,889
    cool.. another ecp one or other supplier?
  31. S3 Paul
    S3 Paul Well-Known Member Regional Rep
    2,821
    105
    These ECP mafs... Without a dyno but with vag com is it possible to check if its duff?
    Mines been on a ECP maf for about 2 years...
    Looking at the vag come numbers its lost power.
    Ive tryed to check what i can but have drawn a blank.
  32. aragorn
    17,884
    688
    Fuel trims can sometimes give you a pointer.
    If its underreadding, it'll run lean, resulting in the ECU upping the fuel trim to compensate.
  33. s3gazz
    1,376
    99
    Iv tried another ECP one just to see if it was duff and still will only read max of 235 g/s no more so must be ok.
    unplugged the actuater again and hey presto only 6 psi after upping the preload
  34. s3gazz
    1,376
    99
    Anyone got a part number for a wideband maf as they might of have me a narrow band one lol
  35. superkarl
    9,326
    2,329
    part number for mafs are defined by the last 3 digits, my wideband one is 049.
    hope that helps somewhat
    s3gazz likes this.
  36. s3gazz
    1,376
    99
    Thx Karl ill have a look
  37. Broken Byzan
    13,235
    464
    That's on the element itself, 040 is NB 049 is WB
    s3gazz and badger5 like this.
  38. aragorn
    17,884
    688
    06A906461E is narrowband
    06A906461M is wideband
    s3gazz and Westy like this.
  39. <tuffty/>
    20,812
    3,665
    ECP/GSF part numbers for the generic Bosch part are differnt to OE... will have a label on the housing and starts with 021 from memory..
    IIRC a narrow band MAF element running on a wideband ECU over reads... have seen this on the dyno before but Bill could confirm this...
    NB vs WB maf scaling in the maps...
  40. aragorn
    17,884
    688
    yeh your right, the narrowband scale is shorter, so it would output more volts for the same airflow, which would show up as a higher reading.
