S3 yello icon symbol?what does it mean?
campbell Jul 2, 2006
  1. campbell
    campbell Member
    726
    its come on in the right hand dial of my S3, its like a yellow squarish symbol, i recently had my car remapped and when i run high boost and it pull its self back its comes on temporary but now its come on all the time
    does anyone know what it means?i was thinking maybe something to do with the ignition
    cheers
  2. Olly_K
    Olly_K Administrator
    2,678
    its not because your car is losing traction is it...could be the traction control light.
    Im sure someone with more knowledge about A3's will help you out in a few hours !
  3. millsyd
    millsyd Member
    114
    what dial does this logo come on at, if its on the rev counter and its a triange with a ! in the middle its traction meaning your nt get any or a wheel is slipping.
  4. Olly_K
    2,678
    he says the right hand dial, so speedo i guess ? puts my theory out the window then !
  5. millsyd
    millsyd Member
    114
    on the right hand dial two are yellow a abs on which (abs) with a circle around the abs, the one by the 40 kph mark which is a weird shape is the ecu/engine noticing a fault.
  6. campbell
    campbell Member
    726
    its on the right hand dial so yes its the speedo, its just a wierd shape, its only just come on, must be my ECU, what does this mean?anything serious or just needs reseting?
  7. madvw
    madvw Active Member
    2,489
    could be the check engine light...
    gonna have to get the DTC's scanned if it wont go off.
  8. The Slug
    The Slug Active Member
    1,869
    kinda squarish, sounds like (Engine Managment) ECU warning light to me.
  9. campbell
    campbell Member
    726
    what are DTCs?no it wont go off, no affecting performance or anything though
  10. FactionOne
    FactionOne Administrator Staff Member Administrator
    3,272
    183
    Does it look something like this?
    Regards,
    Rob.
    Also: DTCs = Diagnostic Trouble Codes - basically a numeric code that is stored on your ECU (or other electronic control module in the car) when a fault is detected that 'uniquely' identifies that fault. DTCs can be 'looked-for' by VW/Audi technicians using their VAS 5051 computer, or by anyone who has VAG-COM (a PC-based (additional interface required) emulation of VAS 5051).
  11. campbell
    campbell Member
    726
    yes its that code, what basically does that mean and can it be reset or sorted?cheers for that advice
  12. FactionOne
    3,272
    183
    If that's the light you've got, it's "Check Engine / Engine Management"...
    This next sentence is both good and bad news... That light can come on for literally hundreds, if not, thousands of reasons.
    ...It could be something very trivial, and not really worth worrying about; but on the other hand it could be something potentially expensive (and in that case moreso the longer it goes unchecked).
    Best advice I would say is get it along to either someone with VAG-COM or a dealer for a DTC scan as soon as you can. I'd certainly be treating her extra-carefully until that point.
    I'm sure if you let us know whereabouts in the UK you are there'll be someone nearby who can help out...
    Best regards,
    Rob.
  13. campbell
    campbell Member
    726
    im from preston in lancashire, if any can do a check for me i would really appreciate it
    cheers
  14. Grant
    Grant Well-Known Member VCDS Map User Audi RS3
    1,206
    118
  15. campbell
    campbell Member
    726
    funny! i havent got a manual and im not clued up on audi`s just yet
