S3 Xenon Headlights into an A3 (8P2)?
Donny_DJ Sep 20, 2011
  1. Donny_DJ
    Donny_DJ Active Member
    444
    118
    43
  2. Ash B
    Ash B Well-Known Member
    5,831
    85
    There was a thread the other day have a quick search. You will also need auto leveling & jet washers. And vagcom.
    A few of the guys on here off to install them for a charge.
  3. vw754
    vw754 vorsprung Durch Technik
    2,351
    58
    you can blow the wiper motor by fitting hid's alot of people have.........do a google search. not sure if genuine audi ones complete with ballasts will be ok or not........sure somebody will be along to give the advice.
  4. NHN
    29,577
    1,779
    OEM headlights wont blow wiper motors & if you're looking for a fitter let me know.
  5. L80EWY
    L80EWY Active Member
    408
    81
    Is it as easy to fit oem bi-xenons as it is to fit the normal oem xenons? Just simple plug in and then turned on with vagcom? Or do bi-xenons need any other wiring etc
  6. NHN
    29,577
    1,779
    Standard xenons from 03-05 use a 10 pin plug & can be plugged in easily with other cars with same connector, but you still need coding the systems to pass the new mot rules coming in.
  7. N8
    17,163
    720
    If you want these fitting, you want Nige on the case, the end.
  8. Ash187
    7,519
    756
