S3 with spacers - RUBBING!!
L60N Jun 14, 2008
  1. L60N
    L60N Guest
    Hi guys,
    Well ive been out for some spirited driving today and the wheels are rubbing like a mofo!!
    So i guess against the warnings ive learned a lesson.
    I really want to keep 15mm to the rear so is there anything anybody can recommend to prevent it? Ive read somthing about removing the screw but its almost flush anyway so isnt the screww actually preventing the trye from ripping my back bumper off?
    LoL!
    I'll get a piccy in the meantime.
  2. jonnyc
    jonnyc Member
    858
    I have modified the rear arch by removing the screw and removing some of the material away from the problem area also..
    My car is lowered on H&R springs and has et42 wheels.. Used to rub all the time but its fine now, apart from the very occasional small rub over extreme bumps
    Ill show you at Inters anyways mate, only took 5mins a side to do and works perfectly..
    Jonny
  3. L60N
    L60N Guest
    Was it in the same area as this Jonny?:
    Which material are you talking about? Do i need to buy a dremel? :)
  4. jonnyc
    jonnyc Member
    858
    Yep, remove that screw and then remove part of the plastic behind the screw with a dremel type tool..
    Dont worry about the bumper moving with the screw removed, mine has been fine since I did the modification about 1000 miles ago..
    I had to do a similar type of modification to the front arch of my Golf GTI, amazing how a tiny bit of clearance makes all the difference..
    Jonny
  5. L60N
    L60N Guest
    Cheers Jonny,
    Driving it over some particularly amazing B-roads this morning and hit a dip in the road, then another, then another. Turned my weekend blast into a bum clenching Gurning competition between me and my mate!:laugh:
  6. JamS3
    JamS3 Active Member
    2,258
    24
    Told you!
    You can even see bits of your tyre behind the screw!
  7. L60N
    L60N Guest
    Yep :redface:
  8. L60N
    L60N Guest
    Well i did what you said Jonny, removed the screw, filed what i thought was enough. Hurled it round the same B road, still some minor rubbing on a couple of occasions (I was really trying this time though).
    Looks like i need to go back with the file when I can be ***** Trouble is I need to jack the car up to drop the wheel down so I can get in *Groan* :)
  9. jonnyc
    jonnyc Member
    858
    Ah that sounds good, i took a reasonable amount of material away but there will be small differences in the tyre shape etc so as long as its only rubbing when your really pushing on down a very bumpy road then i'd say that you'll be ok!
  10. Kontraband
    Kontraband Active Member
    2,008
    ahhh L6ON, your like my test pilot buddy! :respekt:
    Will we still be talking 5 seconds then till i want them?? ;)
  11. L60N
    L60N Guest
    You should go for 10mm to be safe. Or 15mm to be cool :cool:
    DEMIAN YOU TOLD ME THEY WOULDNT RUB!!!!! ARRRRRRRRRRRGHH :motz: :)
  12. phantom
    phantom On Boost
    1,750
    I think 12 mil would be fine a Std ride hight.
    p
  13. L60N
    L60N Guest
    Well ive got more than 3mm of black paint polished off the screw I took out so i'd have to disagree there mate. Someone with 10mm (cant remember who) said they have still had rubbing on bad roads.
  14. phantom
    phantom On Boost
    1,750
    I think that was JamS3 , but he's is lowererd.
    If you think 12's will still rub then fair enough.
    p
  15. L60N
    L60N Guest
    Ah lowering may not help. I definatley have closer to 5mm of rubbing on the screws FWIW.
  16. JamS3
    JamS3 Active Member
    2,258
    24
    Yes mate that was me, to save wasting money on 12mm mill which will probs still rub go for the 10mm and if you are not lowered they should be fine.
  17. L60N
    L60N Guest
    Or get 15mm and set to your arch with a dremel :)
