S3 with Halogens??? Help :(
kav1187 Jan 5, 2012
  1. kav1187
    kav1187 New Member
    Hi All,
    Before I get found out and Booed off the forum I'll own up to being a VW owner. I'm currently in the middle of converting a VW Golf Mk2 Syncro to run the S3 engine, wiring, dash, 4x4 etc etc... (this is where you guys come in :salute:). The S3 I bought seems to have halogen headlights instead of xenons.
    It is a 2000 model (8L) and being an S3, should have xenons, no? It has all the auto leveling sensors fitted and also shows xenons on the VAG COM readings. I know it's been involved in a front end accident at some point as the passenger side has evidence of repairs which leads me to believe that the previous owner cut costs on the repair and fitted halogen headlights instead of xenons.
    What baffles me is that the wiring loom has the correct connector for the halogen lights and it doesn't look like it has been altered. I've taken a pic of the back of the headlights to show the connector:
    From what I can see on ETKA and from pics of the back of the xenon headlights, the connectors are completely different.
    Any ideas??
    Thanks,
    Kav
  2. s3dave
    s3dave TFSI Hybrid Supporter
    10,110
    736
    Im not to sure on the connectors but i believe they all came with xenons....
  3. Rogue-24-84
    Rogue-24-84 Member
    268
    all s3's came with xenons as standard...
  4. kav1187
    kav1187 New Member
    Yeah i thought as much. Can someone with an early S3 have a look at their loom to confirm its defo not the round type as in my pic? Is there a loom in between the round connector and the headlights?
  5. [Dave B]
    [Dave B] Daddy
    2,027
    145
    I don't have a pre-facelift but they look OE to me, and I'm sure all S3's came with Xenons. Pre-facelifts do have different lamps/projectors but I'm sure they're still Xenons.
  6. kav1187
    kav1187 New Member
    Sorry I forgot to mention - the pic is of the halogen headlights that are on the car. The connector on the wiring loom fits these (halogen) lights. I just wanted to see what the connector is like on the xenons.
    Thanks,
    Kav
  7. Gops
    3,197
    666
    What you have is the facelift lights put on there. The preface lift had square connectors. Check your loom, there might be a connector from square to round. If not just keep that loom and run HID kit as the lights will have projectors? I'll try and take a pic if my loom later as my car is on the other side of the hosp here and it's cold outside lol
  8. kav1187
    kav1187 New Member
    Thanks matey, that would be most appreciated.
    I think they're the pre-facelift lights as the indicator is separate. They're defo the halogen ones because there's an H7 bulb with no projector. I'll take some more pics when I get home tonight.
    TBH it's not the end of the world if I use the halogen lights, but I would quite like to fit the xenon projectors/leveling etc to the mk2 golf :rock:
  9. kav1187
    kav1187 New Member
    Ok...mystery solved...I undid the black wrapping from around the cables and....
    Can someone have a look at the colours at the back of their passenger side xenon headlight connector and confirm that the four colours in the pic below go into that connector?
    Yellow/Blue
    White/Black
    Grey/Black
    Brown
