S3 - With a couple of issues- any suggestions?
Mi7rennie Oct 16, 2012
  1. Mi7rennie
    Mi7rennie Member
    82
    Hi Guys,
    Just got my S3 through its MOT and taxed yesterday. She seems to be driving pretty well but has a couple of faults I was hoping you could help diagnose.
    • ESP flashing when accelerating gently from low speed - sometimes this leaves a soft fault until the next start up.
    • ABS light going off when braking gently and also leaving a soft fault on the dash.
    • Temperature gauge will sit on 90 when stationary but drops down as I drive - suspect the thermostat, what do you think?
    The history of the car is that is has been sitting for a few months unused.
    I had to fit a rear ABS sensor I used this one: Audi A3 8L1 Hatch Bosch Rear ABS Sensor Genuine Brake Wheel Speed Sensor | eBay
    The longitudinal acceleration sensor from behind the glove box was missing so I replaced that.
    Apart from that it was just tyres, ball joints and anti roll bar bushings for the MOT.
    Can you suggest any common faults I should check?
  2. s3dave
    s3dave TFSI Hybrid Supporter
    10,110
    736
    I would suggest a 4 wheel alignment mate... esp as you have moved ball joints etc..
  3. <tuffty/>
    21,578
    4,050
    Is the steering wheel on straight when driving in a straight line? dodgy ABS wiring to the sensors sometimes cause this too
  4. Mi7rennie
    Mi7rennie Member
    82
    I meant to mention that, the wheel is about 10 / 15 degrees off the straight ahead.
    It also looks like a lot of camber on the back wheels and I can't see any adjustment, the car is lowered on eibach springs.
  5. <tuffty/>
    21,578
    4,050
    Gotta love it when peeps leave that little bit of info out lol...
    Righty... as said, get a wheel alignment done... the steering wheel needs to be straight as the steering angle sensor will be out of calibration and the ABS/ESP system will think you are turning a corner but get confused as the speed sensors are reading the same and not a differential as the ECU is expecting..
    Rear camber needs adjustable tie bars to bring back in then get a 4 wheel laser alignment
  6. Mi7rennie
    Mi7rennie Member
    82
    OK great, I'll get it booked in for later this week.
    I'm not sure if I can afford the read tie bars just now but at least I'll get the front sorted.
    Would that also explain the ABS getting confused?
  7. <tuffty/>
    21,578
    4,050
    Potentially yes... assuming no other issues exist... get the alignment done first then take it from there...
  8. jojo
    28,935
    3,587
    Assuming you have the same Eibach springs I had previously, the rear camber is not a major issue, unless you are doing mega mileage. Mine wore out evenly at the back, but I do like to take corners quickly in mine!
  9. vrbob
    vrbob Thats no Moon, Thats a space station!
    2,375
    171
    Temp issues is probably thermostat but a vcds scan might point to the coolant temp sensor
  10. Ben S3 8P3
    Ben S3 8P3 Member
    313
    32
    how much does a wheel alignment cost roughly? My 8P3 is probably 3-4 degrees to the left on the steering wheel
