Does anyone know an outfit that could etch the chasis number on the inner (inward facing) part of the mirror housing, so that it could be seen when folded in? I for one fancy keeping the mirrors on my 07' S3
you'll find two small screws under the mirror on the black plastic bit - remove these. (this is not necessarily required, but I've found it makes the casing a bit easier to remove.prt57 said:b) Is there a guide to getting the silver caps off without damaging them in any way at all?
pacnet said:Does anyone know an outfit that could etch the chasis number on the inner (inward facing) part of the mirror housing, so that it could be seen when folded in? I for one fancy keeping the mirrors on my 07' S3
rcourtney said:Hi, PRT57,
a) You can get pre sprayed or just primed from the factory.
Cost of dealer parts (I know I've been back a few times !!)
- Pre sprayed colour coded caps cost £81 / side
- Alu Caps are £168 / Side
- Glass (std - not anti dazzle, not convex etc) costs £23 / side
- Mounts are £58 / Side
- 2hrs Labour charged at £260
Total cost should be £760 for ALU caps and £584 for colour coded from a dealer
I have quoted with a number of dealers, most will try and charge for 3 hrs work .. Audi recommend 2 hrs for the job so make sure you only pay for 2 hrs !! They may also try and charge for anti dazzle or convex tinted mirrors - std work perfectly well !
I currently have Phantom Black colour coded with std glass (etched with No. Plate)
All the sign will do is warn them so, when they do come round for them, they'll be wearing ballaclavas.IH786 said:I can see my S3 out of the bedroom window, and if i hear anything, i always take a qucik glance out of the window. We have CCTV installed and a sign stating that, so if anyone did try something, they would be on tape
S3 LTN said:rcourtney quick question...
How did you etch on the no.plate? And where did you etch them?
rcourtney said:Inside the Caps and on the bottom right hand corner of the glass - its not noticeable while driving but if you look at the mirrors you can clearly see that the number plate is etched on them. After having them stolen twice in two weeks; they havent been touched.
Glass isn't expensive to replace so dont mind marking it inorder to give a visable deterrent. If I move i'll change the glass
Used an etching pen - very cheap and very simple to use
Hope that helps
