S3 Window Regulator replacement
mark_S3 Nov 26, 2012
  1. mark_S3
    mark_S3 Team Silver
    805
    299
    Guys/Girls
    Yesterday i put the O/S window down and once it hit the bottom there was a loud 'crunch' type noise and before you know it, the window wouldn't go back up. So glad it was sunny in Wakefield yesterday as i had a ten mile journey with the window down.
    Anyway once i got home, i popped off the door card and found the window regulator cables have snapped. Now I'm presuming i just need to replace this as I'm sure the motor works because once you touch the switch the motor wants to move but cannot due to the loose wire cable wrapped around.
    So I'm going to order a new Window Regulator kit and replace that. Is that all i need to do? And how hard is it to replace?
    I've read up that i need to pop the old rivots out and can replace with nuts and bolts.
    Has anyone got a guide to replacing the regulator or can write a description of what to do, and also what bolts/nuts i need to replace the rivots?
    Any help would be much appreciated.
    Mark
  2. mark_S3
    mark_S3 Team Silver
    805
    299
    And also, yes i've searched the forum and found little help.
    Just like now. Tried to find out how much coolant is in the system as i plan on doing a full flush and renew the antifreeze with G12+, but after 45mins on the search function with 'coolant', 'antifreeze', 'fluids', 'G12+', etc and still i haven't found the simple answer.
    How much fluid is in the coolant system so i know how much G12+ to buy? I know its a 60/40 mix with water.
    Thank you.....
  3. WorkInProgress
    WorkInProgress Member
    253
    I'm interested in this too, have found some useful threads on this and have just bought this off Ebay, mine is a 5dr but I imagine fairly similar process. Had a look today and I think you'll need to remove the door subframe to get access to everything.
    Have a look here to see if that's of any use to you
  4. Alex C
    Alex C Well-Known Member VCDS Map User Audi S3
    3,294
    372
  5. mark_S3
    mark_S3 Team Silver
    805
    299
    Thank You guys.... Thats the info I needed, and now I have the stressful job to do.
  6. vanilla_ice
    vanilla_ice Active Member
    714
    Thread revival.
    It appears my cable has snapped. Window doesn't go up or down. Can hear motor run for a short while when I click the window up.
    Is this part suitable for the repair? - http://www.ebay.co.uk/itm/Audi-A3-8...t-2-3-doors-Front-right-AU32RST-/141379171591
    Is it worth getting genuine window clips to replace the included clips, or are the included clips unlikely to fail?
    Following this guide in the stickies, is it only the one rivet to drill out to carry out the repair?
    Thanks in advance.
  7. vanilla_ice
    714
  8. <tuffty/>
    21,697
    4,124
    I'll let you know when it happens to mine :)
    ...although I would probably use genuine kit...
  9. vanilla_ice
    714
    Thanks <tuffty/>. Would you know if there is such a thing as a genuine repair kit, or would you source a second hand unit?
  10. <tuffty/>
    21,697
    4,124
    I doubt its genuine but if you look on partsbase.org (link in the parts number sticky) then you can at least see what VAG do in terms of a 'kit'
    I suspect not as 'repair kits' like this are generally in response to a recognised problem and the cars are too old for VAG to worry about sadly so its left to the aftermarket to make up the shortfall
    vanilla_ice likes this.
  11. rhinopower
    rhinopower Member VCDS Map User
    223
    21
    Good luck fitting that kit! tried for hours, the cable was either too long or too short, its still sat there broken.
  12. vanilla_ice
    714
    Did you ever fix your window @mark_S3 ?
    If so how?
  13. mark_S3
    mark_S3 Team Silver
    805
    299
    Yeah i managed to fix the problem but not without its issues.
    I brought a new regulator cable kit off ebay (contained cable and clips)
    I then fitted this, but wasn't long before what I believe the cable jumped off and wrapped it self's around the motor pully which kinked the cable.
    So for over 12months I went without a working window until I purchased a 2nd frame with working regulator and motor. (I cleaned this up and greased the pullies) then fitted this. No issues since...
  14. vanilla_ice
    714
    Many thanks, I was thinking I might go down the same route.
    Any alignment issues when refitting? The guide suggests marking the wedges etc. Can you share any advice on that?
    mark_S3 likes this.
  15. mark_S3
    mark_S3 Team Silver
    805
    299
    Unfortunately all my marks where on my old frame.
    I took some measurements off these marks on my old frame, to get it aligned to somewhat a rough position. Then I had to keep tweaking the frame into the perfect position.
    There's some fettling and tweaking to get it right but it's not hard tbh. Just some extra time doing it.
  16. rhinopower
    223
    21
    I bought a new frame from scrappy today for £20, will put my new clips on and bolt it in tomorrow.
  17. vanilla_ice
    714
    How did you get on?
  18. rhinopower
    223
    21
    Absolute doddle to fit. I lined it up with the marks i made from the old frame, and it lined up perfect when i closed the door. The new frame looked like it had a recent replacement regulator too so double win :)
