S3 wheel upgrade and brakes advise needed
GGB_8PTDI140 Feb 10, 2014
  1. GGB_8PTDI140
    GGB_8PTDI140 Audi modder
    I have a A3 2006 2.0TDI 140 PD 5Dr I am planning on fitting 315mm front and rear brake setup from am R32/Seat/S3 or VRS I think I'll try go for the VRS as I like the green but I want S3 wheel and wonder if these will clear OK? I understand they are 17inch could anybody help with the model name???? My wheels are already 16inch and DON'T want 18-19inch so will 17's clear the brakes OK? Thanks peeps
    Gary
  2. JimboS3
    JimboS3 Active Member
    261
    134
    43
    This post is a little confusing! The wheels above are s3 speedlines and are 18"
  3. GGB_8PTDI140
    Yes Jimbos3 I have 16inch wheels fitted already and i want no bigger than 17 (I thought the pictured wheels were 17 not 18) I want the brake setup as noted above and wondered if they would fit under 17's or will I need bigger wheels? Thanks for clearing up for me that speed lines are 18's.
  4. JJ.Foulds
    JJ.Foulds Well-Known Member
    1,263
    176
    i have stock 17's and i have the R32/S3 brakes and they are 345mm i believe and just clear with no spacers.
  5. c_w
    c_w Well-Known Member
    1,163
    87
    I agree there is a lot of confusion in your post, that is a red herring photo! The S3 has much bigger brakes, 345mm front discs. Is this the size you want to fit?
    I understand the 312mm setup will fit under 16" wheels as this is a common winter wheel size fitted to people with this size brakes. So obviously 17s will be fine.
  6. vikingjonas
    vikingjonas New Member
    I've got the S3 wheels pictured on my A3 and they are 18s....
  7. KemiksiZ
    KemiksiZ Active Member
    570
    142
    43
  8. pablo
    pablo Active Member
    985
    60
    can confirm 17" audi a3 sport wheels will fit over S3 brakes.
  9. KemiksiZ
    570
    142
    43
    Yes as diameter BUT I think the ET values will be also suitable.
  10. pablo
    pablo Active Member
    985
    60
    no - I have a set and ran them over winter. they DO fit.
    its close but fine.
