S3 Wheel spacers
88888888 Feb 17, 2010
  1. 88888888
    88888888 Approx give and/or take
    12
    Hello, I wanted to ask if anyone had any experience with wheel spacers on the 8L S3.
    I want to space the standard 17" Avus alloys outwards until they are as close to level with the top of the wheel-arch.
    Do you think there's a danger of the tire scrubbing the arch if I fit 60mm spacers when I'm running factory fit shocks and springs?
    Thanks, any advice would be really appreciated.
    Dan.
  2. Lemon S3
    Lemon S3 Alex
    1,390
    41
    60mm :ohmy: are you mad?? Thats going to put a lot of strain on your bearings, the most anyone else has done is 20mm like myself and it looks awesome and you don't get any rubbing. You will most likely get rubbing with 60mm spacers on.
  3. 88888888
    12
    Haha, is that really mad idea? I see.
    To be fair, it was a complete estimate by me. I had it in my mind that each wheel being brought forward by 3cm would only achieve a subtle visual change to the stance. So you think 10mm per side would change the look of the car then?
  4. DPM
    DPM Site Sponsor Site Sponsor
    5,023
    206
    I'd say 20mm rear and 10mm front will be more then enough.
    Damian @ DPMPerformance
  5. 88888888
    12
    More than enough visually?
  6. JS1500
    JS1500 Howdy
    1,166
    10
    They are talking per side 888888888.
    I've got 10mm (per side) fronts and 15mm (per side) rears.
    When you buy them most places will give the width per side. You should get some that are 'hubcentric'.
    Got mine from PW Motorsport (site sponsors) for around £100 including bolts...
  7. Lemon S3
    Lemon S3 Alex
    1,390
    41
    When you first said 60mm, did you mean 30mm each side, 60mm in total?
    I have 20mm on each wheel and I wouldn't advise to go any further really and it is visibly noticeable.
  8. 88888888
    12
    Right, thanks for clearing that up for me
    mate.
    So do you think 20mm each side, front and rear is going to see me scrubbing the arches?
  9. Lemon S3
    Lemon S3 Alex
    1,390
    41
    No you'll be fine with 20mm each side front n rear as I've got 30mm lowering kit with 18inch wheels and I haven't had a problem even with a full car.
  10. 88888888
    12
    So am I right in thinking I'd be asking for 2 x pairs of 40mm hubcentric spacers?
  11. DPM
    5,023
    206
    The S3 has a wider track as standard at the front so I personally think it looks better if you go for around 10mm more at the rear to even it out.
    Damian @ DPM Performance
  12. 1animal1
    9,978
    hmmm, £100 for spacers and bolts....im extremely tempted and i dont spend money easily , especially on stuff like this
  13. JD09
    JD09 I'm not modding, I'm improving VCDS Map User
    3,096
    46
    Spacers had a huge effect on the handling and looks of my old Clio. I think they will be on the list once the new wheels arrive. Hubcentrics are a must, just to re-itterate that.
  14. Westy
    Westy Well-Known Member
    17,443
    1,104
    I got a set of brand new anodised 15mm spacers and a set of 10mm spacers off ebay at the weekend for £35 without bolts and then £45 for a set of bolts from Badger Bill :)
    Putting them on this weekend.
  15. 88888888
    12
    Are your shocks new?
  16. vetch
    vetch S3
    430
    As did I, well only rears actually. Im assuming we got them from the same guy? He is selling more now. I havent sourced bolts yet, I'll only need rears so Im hoping to pay no more than £20-25. I cant wait to get them on the car.
  17. Westy
    17,443
    1,104
    Yeah there was some company flogging a load of old stock, all of the auctions started at 99p with no reserve. Mine turned up yesterday, nice quality spacers.
    Bargain hunters :)
  18. 1animal1
    9,978
    good find mate!!
    is that including locking nuts?
  19. JD09
    3,096
    46
    I think that price will be for just spacers lad.
    Out of interest, Westle, are you using extended bolts with the 15mm spacers, or bolting the spacer to the hub, then the wheel to the spacer with the original bolts?
  20. Westy
    17,443
    1,104
    £35 was just for all four spacers. I bought longer bolts from Bill for £45. Bill has cut sown the front ones for me because apparently they will rub on the ABS hub. I dont have locking nuts as they were about another £40 for a decent set. If someone nicks my standard 17" Avus I'll just buy some 18" ones :)
  21. JD09
    3,096
    46
    Oh nice, I thought you meant 35£ a pair! Link me!!
  22. Westy
    17,443
    1,104
  23. 1animal1
    9,978
    Cheers JD.... he did point out the nut cost ;) also thanks for the 'lad' compliment, doesnt happen very often these days and makes me feel 20 again :)
    Westle, top man.....this was the stumbling block before for me, the locking nuts - dont want anyone stealing my genuine none refurb RSTT's ;)
