S3 wheel spacers. Have I gone too big?
Rrobson Apr 3, 2014
  1. Rrobson
    Rrobson Member
    37
    Since buying my s3, I have always been a little disappointed by the wheels looking a little lost in the arches. I am happy with the height of the standard suspension but wasn't with the wheels.
    So yesterday I made a pair of 20mm and a pair if 10mm spacers.
    So I've fitted the rears today but I don't know if I've overdone it a bit.
    Since fitting I've read that 12mm on the rear is the preferred size for oem wheels so I may take a bit off them.
    Colleagues who have seen say it looks miles better but it may grow on me.
    Anyway, here's some comparisons, see what you think.
    Before
    After
  2. Westy
    Westy Well-Known Member
    17,443
    1,103
    I think they look spot on but needs to be a bit lower to look really good.
    warren_S5 likes this.
  3. warren_S5
    warren_S5 Moderator Staff Member Moderator VCDS Map User
    7,210
    2,486
  4. LEE69
    LEE69 07 170 DSG Team Dolphin Grey Audi A3
    2,209
    389
    20mm is bang on. Matches the front now imho
  5. Connorb5anda
    Connorb5anda Member
    42
    I have a set of 12mm kicking around the garage, after seeing this im definatly getting some 20mms for the back too! Just right imo!
    Westy likes this.
  6. S.
    S. Save the manuals Team Ibis TFSI Owners Group Audi S3 quattro Manual
    2,006
    546
    looking good!!! i've got 12 all around. but after seeing this i wish i went at least for 15 for the back.
  7. hades-
    9,481
    646
    they do look good
    but 25 would look even better
  8. Rrobson
    Rrobson Member
    37
    Thanks for the comments. I'm going to have a good look I the morning but I do t think the pics really do it justice... They looked totally different one side to the other while fitting.
    Bez, 25's would probably take them right to the edge of the arch but I wouldn't expect to get any passengers in the back incase the wheels started rubbing on it!
  9. S3_Jacko
    S3_Jacko Well-Known Member
    1,735
    574
    I done something different but it'll give you an idea... I put wider wheels on mine with a lower offset.. But mine stick out 17mm from the standard wheels and I think it is just right!
    Westy and warren_S5 like this.
  10. smurfworth
    smurfworth Well-Known Member Audi S3
    1,929
    542
    As a safety thought, and I'm sure you've thought of it too but I hope you've got longer wheel bolts.
  11. Rrobson
    Rrobson Member
    37
    Jacko, that looks perfect. I think that's where I'd like mine to stop. Wheels really suit your car but I actually like the standard wheels on mine. Think 15mm would be better for me.
    Smurfworth, I wouldn't even consider using standard bolts on any spacer. Not that standard bolts would even start...
    I bought 50mm bolts, but got sent 60mm? Chopped them down at work but something to check when buying. Could you imagine if they were 10mm short...
  12. smurfworth
    1,929
    542
    By looking at the table in the pic of the spacer I guessed you were and engineer of some sort hence why I thought you'd had considered it, but you never know with some people haha.
    But yea, I could imagine some daft person having them tightened by 2 or 3 threads.
    My opinion on the matter is I'd prefer to do what jacko does, wide wheels and a low offset. Fills the space better. Bit looks fine otherwise.
    Westy likes this.
  13. LEE69
    2,209
    389
    Standard bolts are 27mm length so just add the thickness to them, for the bolts you need.
    Or if going 20mm use the spacers that bolt to the hub, then the wheel bolts to the spacer and means you use the original bolts and lockers
  14. NHN
    29,332
    1,716
    You made these yourself, If so, then very impressive, well done :)
  15. Jonathaan
    Jonathaan Quattro
    720
    120
    43
    Looks bang on m8!
    And a little cheeky turning and drilling exercise lol
  16. Xendric
    Xendric New Member
    I've done exactly what Jacko did, same wheels (they're 8j et43) and added a 5mm spacer in the back. Getting a set of pss10s on the car next week, so it 'll look pretty much how his car does, which is great. Thanks for sharing the pic Jacko,I now know I made the right choice.
    That said, I get some rubbing at the back but that's probably down to the spacer, but since I like the poke, I'll try to trim the little screw that's responsible for it and hopefully it'll be gone.
    I reckon an 8j et42-45 wheel, or equal with spacers, will give no rubbing and most aftermarket wheel makers recommend this spec for our cars.
