S3 Wheel fitment: 19x8.5 ET45 fitment on lowered on H&R coils
yahyar Jun 23, 2011
  1. yahyar
    yahyar Member
    hi guys
    got a set of 19" r8 v10 replicas. i was advised they would fit.
    test fitted with
    235/35/19
    huge rubbing issue at the back.
    Will 225/25/19 be any better? or will i continue to suffer rubbing due to ET45 offset?
    it's a shame cos i really like the look
    [​IMG][​IMG][​IMG]
    J.R. likes this.
  2. Lings
    Lings Active Member
    2,059
    31
    215's you want
  3. basssound
    basssound Member
    203
    10
    Get ready for £100 per tyre and thats just cheap **** rubber as well :(
    How low have you gone on the coilies?
  4. warrenlord
    warrenlord Member
    771
    15
    225 35 you could get away with too.
  5. N8
    17,163
    718
    215 for sure, 225s shud be ok, 235s are like an ex-wife "a big mistake" :laugh:
  6. J.R.
    J.R. "Started From The Bottom" VCDS Map User
    1,405
    68
    Love the Wheels Mate ......It's now My Top 5 REPS OEM Audi a3 Wheels of all time for me right about now......:drool::drool::drool::drool::drool::drool::drool:
  7. TimG
    TimG Active Member
    942
    45
    I run an 8.5x18 ET45 with a 225/40 tyre and no rubbing ;)
  8. N8
    17,163
    718
    Thats 18s bro
  9. TimG
    TimG Active Member
    942
    45
    Shouldnt think it'd make a massive difference to clearance though if the widths & ofsets match.
  10. N8
    17,163
    718
    It does make a difference though Timmy G
  11. TimG
    TimG Active Member
    942
    45
    I guess all it takes is a tiny difference between clearing/ rubbing!
  12. Lings
    Lings Active Member
    2,059
    31
    millimetres
  13. yahyar
    yahyar Member
    Thanks for the help so far...
    Here in SA we are very limited: the rim only available locally in et45. pity for me, but apparently it should be fine according to just about everyone? my car is probably just too damn low.
    I want to try the 225/25 to see. i should also ask the shop to raise the rear a bit more. this is adding a lot to the problem. 215's are very expensive here and might be a bit on the narrow side for our roads.
    a buddy suggesting machining 3 millimetres from the rim. i'm sure many people wouldn't advise this route but anyone here been successful with this method?
    the height is probably sitting at around 40mm on all corners right now. on the 18's, the coils were maxed out (i think 60mm) all corners
    here's a before pic of the standard 18's on the coils
    im tired of the old wheels and sweeping the streets, so hopefully i can get these reps fitted!
  14. N8
    17,163
    718
    You can shave but There is no point just go for thinner tyres
  15. yahyar
    yahyar Member
    aye aye captaiN8!
    will report on it next week! fingers crossed
  16. yahyar
    yahyar Member
    225/35 not working - still rubbing. suggestions?
  17. Cheese
    Cheese Member
    182
    Can't you use some sort of spacers or something to move the wheels out from the car body slightly?
  18. moag
    moag she's no d-turbo
    821
    35
    That makes the problem worse! moving the tyre closer to the wheel arch = more rubbing
    215/35s if you want to go right down on the coils
  19. moag
    821
    35
    great looking car by the way man, those wheels look bangin
  20. Smoothie
    Smoothie Active Member
    1,431
    Dear God! Do not listen to this man! Is it rubbing constantly mate or just dips in road etc? The 215 is a well tried/tested solution on here but you say your roads wouldn't be suitable and since you've went to the expense of the 225's now you might want to shave few mm off the wheels...I've seen this done before
    Also car is lovely, especially running that low on standard rims! Never been a fan of Reps in the slightest but can't take away from that, looks well
  21. N8
    17,163
    718
    215 it is
  22. Kash3838
    Kash3838 Member
    185
    19
    raise the suspension slightly, or take the rims back and order 8x19" et45
  23. Cheese
    Cheese Member
    182
    I see - so bigger wheels rub on the outside of the wheel arch not the inside. Sorry for the unhelpful suggestion OP!
