S3 Washers
tward11 Oct 19, 2011
  1. tward11
    tward11 New Member
    Hi Has anyone fitted "misting " spray washer jets to their S3 , My wife has them as standard on her MK4 Golf, but if you can fit them to S3 what ones do i need & is it a hard job?
  2. DJ_Troopa
    DJ_Troopa K1 Driver
    1,743
    15
    What's 'misting' spray washer jets?? We have washer jets under the headlamps if that's what you mean??
  3. jcs356
    jcs356 Brum brum
    2,734
    70
    They squirt a mist out of them onto the screen, rather than two distinct jets. VW started fitting them in the late 90's but Audi were a bit later to the party so think they came in on the 8P. Also known as fan washer jets as that's what it looks like when they are used.
    I can remember a thread from a while back - problem was that VW have them mounted on the underside of the bonnet rather than on the scuttle. I'll have a search and see what I can find...
  4. jcs356
    jcs356 Brum brum
    2,734
    70
  5. tward11
    tward11 New Member
    cheers mate
  6. <tuffty/>
    21,869
    4,198
  7. fingermouse
    fingermouse thats me
    4,013
    116
    forgot I was going to try and do this mod a few years ago lol
  8. doublem_1
    doublem_1 Member
    500
    I have always wanted to do this mod too. So are the TT ones a direct fit?
  9. SiGainey
    SiGainey Member
    506
    10
    Nope, they definitely require a trim at least. Not a big job though...
  10. fingermouse
    4,013
    116
    Well bought one so will give it a go see if I like the results
  11. fingermouse
    4,013
    116
    Just fitted one, was a shame the angle wasn`t right when it just clipped in place so im having to raise the front slightly and glue it in place. Just hope ive got the angle right now lol
  12. Smokey_clark
    Smokey_clark 12th Gear
    210
    Good man, i've wanted to do this for ages. Can you get a pic of it when fitted please to give me an idea?
  13. fingermouse
    4,013
    116
    Only done the drivers side as I only got 1 washer to try. Pic should be below I just need to add a small silicon bead to finish it off.
    Didn`t think it was going to work 1/2 way through as its v tight to get the pipe back on as the conection is at a different angle.
  14. <tuffty/>
    21,869
    4,198
    Need a video of what the jet looks like...
  15. fingermouse
    4,013
    116
    ill try , it looks a little high but thats how the golf is set stationary. to do the passenger side the wire would need extending :(
  16. <tuffty/>
    21,869
    4,198
    Extending the wires is easy enough....
  17. fingermouse
    4,013
    116
    Its is its just more to do lol I might try and make a wedge to fi under the washer so I can adjust it and fasten it in differently just didn`t have the stuff to do that today
  18. fingermouse
    4,013
    116
    ok heres a vid (if it works ) one done and just ordered another to do the other side.
