S3 Uprated Coilpacks
ben_harmer32 Jan 22, 2014
  1. ben_harmer32
    ben_harmer32 Member
    111
    Does anyone make uprated coilpacks for the S3 (1999)?
    Remember upgrading on my skyline and it made a huge difference.
  2. <tuffty/>
    21,784
    4,169
    There is an 'upgraded' one apparently, silly expensive and largely pointless...
    There was also a huge thing about TFSI coilpacks too which is mostly rubbish too...
    There is a TFSI coilpack thread in the FAQs
    I have been running TFSI coils for a little while they made no difference to anything other than making my pocket lighter... even running the 1mm gaps did nothing measurable on the dyno...
    TFSI coils look good if you use the expensive alloy adaptors (or just as good with the the OE plastic ones) but they work no better than a new set of 20v ones IMO...
    I've not yet managed to blow the spark out with 2bar and a GT3071 and TFSI coil packs still fail like 20v ones so the choice is purely cosmetic...
  3. <tuffty/>
    21,784
    4,169
    Okada is the brand from what I have found out and are like £100 or more each... vs 30 quid each for OE
  4. sssline
    sssline Active Member
    134
    40
    I'd second what tuffty has said about TFSI coil pack, when I spoke with Badger5 he told me much the same so no point going to extra cost when unproven.
    Tuffty do you know if the TFSI coil pack lasts longer? I've read this somewhere recently...
  5. <tuffty/>
    21,784
    4,169
    Not sure that any of them are any better than each other tbh mate... I am using 07K 905 715 F
  6. ben_harmer32
    ben_harmer32 Member
    111
    Cheers guys.
    So is it worth getting replacement standard ones and colder grade plugs instead?
    Car has been mapper and has exhaust, filter etc..
  7. VAG-Slag
    VAG-Slag Well-Known Member
    1,771
    409
    also if you still have OE coil packs its worth remembering that they are on recall and you may be able to get them all swapped out for free...
  8. ben_harmer32
    ben_harmer32 Member
    111
    How do I know if I have OE ones?
  9. <tuffty/>
    21,784
    4,169
    Should mention at this point that you have an APY engine code so these will be bolt down coils... they will have the 4 ring logo and hitachi (beru on the latest revision) embossed on them..
    Bolt down OE packs are generally regarded as being more reliable than push down types... but like anything they do degrade over time and you will always benefit from new replacements... however pattern part coils are generally rubbish...
    TFSI coils (push down) can be made to fit APY cam covers using either the pricey alloy adaptors or the amazingly cheap OE adaptors...
  10. mattyboy199
    mattyboy199 Well-Known Member
    1,890
    29
    TFSI coils are cheaper by about £40 a set.....so if you need replacements its makes sense plus if you have a BAM engine car you don't have to run adapters it just makes it look more pleasant.
  11. bigray
    bigray Active Member
    144
    53
    don't audi do a new coil pack ? as it re call part ?
    or is that just replace old with new ?
  12. sssline
    134
    40
    So they're straight swap? Didn't know that...
  13. <tuffty/>
    21,784
    4,169
  14. sssline
    134
    40
    I read that thread. Oem plus is what I'm aiming for in general. No point going to extra cost when there's so much else to spend on.
  15. Tooks
    Tooks Active Member
    753
    30
    I know the general consensus is to avoid aftermarket coil packs, but I purchased 4 brand new BERU branded packs from GSF about 20 months ago (circa £80 for the set with a discount code, normal price £100ish for four) and they haven't missed a beat.
    They do some cheaper ones too, as well as OEM ones that are more pricey than from TPS etc, but it was late on a Saturday and nowhere else was open etc.
    I believe BERU make coil packs for VAG now anyway.
