S3 turning over but not firing
Jonesymk2 Dec 10, 2013
  1. Jonesymk2
    Jonesymk2 Member
    141
    Finally got my s3 running Saturday,took it for a run round the block to clean the brakes up as it had been stood a while,while I was out it popped a boost pipe off,I managed to limp it home an it kept cutting out under strain cause of the pipe being off,I got home and turned the car off and left it till Monday night,I put the hose back on and then the battery was flat so tried jump starting it but nothing,tried again today with a charged battery and still nothing,I plugged the works diagnostic machine in and a few faults showed up so cleared them and still nothing,tried a live data test and it wasn't showing any rpm signal while turning over,I swapped the crank sensor for one that came out of a running car and still nothing,tried yet another sensor which again came out of an engine that I knew was running an still no joy,Ive checked all the fuses and there was only 1 fuse gone in number 7 which is for the reverse lights,I've checked the plugs on the coil packs and got a live and earths to those aswell,checked the engine control relay and that's still working,I'm stumped tbh as can't be the coil packs as they were brand new ones and only got put on the car Saturday,anybody got any other ideas atall please as really getting fed up now
  2. Broken Byzan
    13,237
    466
  3. Jonesymk2
    Jonesymk2 Member
    141
    Sorry forgot to say it's getting fuel as had the plugs out a couple times and they were wet
  4. Sham101
    Sham101 Member
    286
    20
    immoberlized
  5. Sham101
    Sham101 Member
    286
    20
    were are you based?
  6. Jonesymk2
    Jonesymk2 Member
    141
    The ecu I've got has had the immobiliser defeated though,I'm in Luton
  7. s3dave
    s3dave TFSI Hybrid Supporter
    10,110
    736
    Try bumping it? or get someone to tow you, it might be flooded with fuel
  8. <tuffty/>
    21,879
    4,202
    You say there were a few fault codes but not posted them... they may have been relevant?
  9. Jonesymk2
    Jonesymk2 Member
    141
    I had the spark plugs out and cleaned them up,one code was for 1 of the knock sensors,one was a crash sensor which is always there for some reason,the other 2 were low voltage which I presumed were from the battery going flat
  10. Jonesymk2
    Jonesymk2 Member
    141
    Is there a relay for the injectors anywhere atall
  11. Jonesymk2
    Jonesymk2 Member
    141
    Got spark and there's fuel getting to the fuel rail but only when the car is turning over,doesn't seem to have much pressure behind it either,is there any way to check the injectors are pulsing atall
  12. s3dave
    10,110
    736
    Check the voltage while somebody turns it over.. i wonder if the pump is tired?
  13. 16Klappe
    16Klappe I <3 Panda's! Supporter
    5,795
    1,187
    Crank sensor.
  14. s3dave
    10,110
    736
    Usually throws the code Jardo...
  15. Jonesymk2
    Jonesymk2 Member
    141
    I've got spark there so surely if the crank sensor was at fault I wouldn't have spark,will check the pump later when I get home
  16. s3dave
    10,110
    736
    ^^ Correct^^
  17. 16Klappe
    5,795
    1,187
    If you unlock the car and open the door can you hear the fuel pump prime.
  18. Jonesymk2
    Jonesymk2 Member
    141
    Do they normally prime when the door is opened then,have never really hear it before so will check when I get home
  19. 16Klappe
    5,795
    1,187
    Yep.
    If it doesn't prime, check the relay.
    The relays are behind the knee pad, to the right of the steering column. It is the lower right hand relay, marked 409.
  20. Jonesymk2
    Jonesymk2 Member
    141
    Ok cool cheers that was going to be my next question where the relay is lol
  21. Jonesymk2
    Jonesymk2 Member
    141
    [​IMG]These are the relays behind the trim but none marked up 409 :-/
  22. Jonesymk2
    Jonesymk2 Member
    141
    The car is a T plate apy car so not sure if anything will be different
  23. s3dave
    10,110
    736
    The 167 on your pic should be the fuel relay, not sure if its the wrong relay or not, but it obv has been running...
  24. rustynlc
    rustynlc Member
    186
    20
    I had a fault with my immobiliser kicking in so stopping the engine from starting, chucked it on vagcom and basically turnt out to be a flat battery in the key, not sure if this is the same problem as yours but worked for me,
  25. Jonesymk2
    Jonesymk2 Member
    141
    I've got power to the pump when cranking it over it's showing about 9.5 volts
  26. Jonesymk2
    Jonesymk2 Member
    141
    When cranking should the injectors pulse or have a constant live,also should both sides get power through them as I would have thought one wire should stay as an earth :-/
  27. Jonesymk2
    Jonesymk2 Member
    141
    Well it seems like the pump is knackered,undone the inlet manifold and cranked it over and the 1st spray from the injectors seemed good but each spray after got less and less till no fuel came out so think pump or blocked filter so just going to do both
  28. John ler
    John ler Member
    157
    What was the problem in the end
