S3 turbo kick, high revs
AL_B Jul 17, 2007
  1. AL_B
    AL_B Well-Known Member Team Daytona Audi S3 DSG
    1,772
    213
    Hi guys,
    Has anyone else experienced this...
    Accelerate to quite high revs, say 4500/5000 rpm, hold the throttle for a few moments, then floor it, then there's a split-second pause, then the turbo/boost kicks, but kicks in strong. Like you've just lit the fuse paper and the rocket has ignited!
    It's the way and the strength that it kicks in that's got me curious. To me it feels like a switch!! Anyone else experience this?
    I'm also wondering if the length of pause (or perhaps lag, or perhaps even hesitation?) is anything to worry about. God knows, I had enough problems on my 8L S3 with hesitation, I hope this one isn't going the same way.
    AL
  2. Staz
    Staz is a retronaut Moderator VCDS Map User
    6,206
    67
    I remember reading, may have been on here, that cars are now fly by wire on the accelerator because they can force that small delay when you suddenly push the pedal. They do it to reduce emmissions. Can't remember the science behind though it sorry.
  3. jamiekip
    jamiekip Guest
    perhaps to eliminate accidental stabs of the throttle (from going over severe bumps) resulting in a jerky ride and more emissions as mentioned above.... complete stab in the dark, but kind of makes sense!
  4. DaveS3Turbo
    DaveS3Turbo Sepang Blue S3
    1,065
    It's normal. Tried it on mine.
    DM
  5. SSS3
    SSS3 Member
    39
    yep yep quite normal - the higher the rpm is held - the more "lag" you'll have when punching the throttle. Boost isn't directly linked to the rpm like that , you need load to spool the turbo.
  6. sjahS3
    sjahS3 Member
    167
    Yep, seems to be quite normal. Tried it on mine also and the same.. :)
    Even a gradual build in acceleration as opposed to a mash throttle into floor shows the same behaviour :cool:
    -Sal-
  7. Spin140
    Spin140 Well-Known Member
    2,196
    186
    Same here, love it, tends to make me swear in a good way :)
    Along the lines of " Oh fiddlesticks this blighter is fast !!!"
  8. AL_B
    1,772
    213
    Cheers guys. At least its common amongst our cars.
    Spin140
    hahahha
    AL
