S3/TT Performance clutches
Andrew@A.L.D Dec 13, 2009
  1. Andrew@A.L.D
    3,879
    617
    What options are out there as there a bit thin on the ice when you do a search on here or google?
    There doesn't seam to be much to choose from out there? you get standard ones at £150+ to £1300+ for the solid flywheel and uprated items?
    Is there something in the middle that uses the duel mass flywheel but a performance item as well
  2. Andrew@A.L.D
    3,879
    617
  3. <tuffty/>
    21,874
    4,201
    Its gearbox dependant IIRC, some 5 speed A3 boxes are actually 6 sped box casings with 6th removed.
    mat20vt had this issue I believe...
  4. Andrew@A.L.D
    3,879
    617
    I will be fitting a new clutch to the new engine when done so i would to fit a performance one if i can
  5. <tuffty/>
    21,874
    4,201
  6. Andrew@A.L.D
    3,879
    617
  7. Gareth_RS3
    Gareth_RS3 Member
    125
    What sort of power are you running mate? Best bet is the uprated sachs item think most people have gone down that route.
    Before I sold mine i was going to fit a fidanza lightened duel mass flywheel with the sachs item which supposed to be a good combo pm me if you want anymore details as im selling it soon as i no longer have the car
  8. frumpy_pigskin
    frumpy_pigskin THE VW TECHNICIAN
    Got My self a Sachs paddle clutch anf pressure plate with a lightened sachs flywheel, its got some bite!!!! word to wise, get your clutch pedal off and get an extra weld on it if your planning a clutch upgrade!:weight_lift2:
  9. Andrew@A.L.D
    3,879
    617
    I don't want to go down the single mass flywheel if i can
    Tuffty's option sounds the best so far. TT with 400bhp, DMF, Std Cover and just a plate upgrade sound good
    Just got to find out where to get the uprated plate from
  10. <tuffty/>
    21,874
    4,201
  11. Andrew@A.L.D
    3,879
    617
    Thanks Tuffty
    Thats the info i was wanting.
    If you can get a part number on the plate that would be even better
  12. <tuffty/>
    21,874
    4,201
    Just give um a call, they will at least be able to point you in the right direction if nowt else...
  13. Andrew@A.L.D
    3,879
    617
