S3 Traction control/ABS problems
Daz A3 TDI 130 Jan 22, 2007
  1. Daz A3 TDI 130
    Daz A3 TDI 130 Warp factor 10
    Hey guys,
    trying to help a friend of mine out with his S3. He has only had the car a little while and the warning light for the traction control keeps flashing.
    Plugged it into my laptop and it seems to be a faulty yaw sensor but Audi want £305 plus VAT for this part! Any idea where i can get a cheaper one??
  2. campbell
    campbell Member
    726
    if you know what part it is/have the part number try vagparts.com
    hope this helps, should be a lot cheaper
  3. Stewart
    Stewart Member
    705
    10
    Whats the code that displays in VAG-COM for the part?
    For example, the lateral acceleration sensor would come up something like :-
    Lateral Acceleration sensor (G200).
    On earlier cars the yaw sensor and lateral acceleration sensor were separate. On later cars (facelift and above) they were replaced with a combi sensor (Although still 2 separate sensors, just located next to each other).
    The earlier yaw sensor is located behind the glovebox and is the dearer one of the two and £305 sounds about right.
  4. ste.B
    ste.B New Member
    10
    I've got exactly the same problem on my 2000 S3 - the ABS light and the traction control light (! in a triangle) keep randomly coming on and rather annoyingly staying on.
    Had it MOT'd recently and the guy at VA autos had the computer in it - diagnostic was a faulty acceleration sensor which he says was around about £250 brand new.
    I'm hoping he will determine which part is faulty and be able to just replace the one part rather than the whole thing... Fingers crossed it's not the yaw sensor!!
    Does anyone know whether continuing to drive the car while this fault is active will do it any harm? Am I right in thinking it just means the anti lock brakes won't kick in and neither will the traction control???
  5. superkarl
    superkarl MAN OF STEEL
    9,610
    2,481
    No Danger in still driving it, those two things are just dissabled. Hope you sort it ok. I got rid of ny abs light with a longitudinal acceleration sensor. Tc one remains though:(
  6. alijames
    alijames Active Member
    1,024
    The only thing to watch, is that if you were to have an accident, and an accident investigation proved you were driving the car with known faulty ABS, there could be insurance implications. Highly unlikely, but theoretically possible.
    Cheers,
