S3 Top Mounts
Sandip Aug 31, 2007
  1. Sandip
    2,440
    91
    replaced my top mounts today as you can see they look worn out, i had a knocking noise thought it was my anti roll bar bushes replaced the top mounts instead and the knocking has gone and the ride is brilliant. [​IMG]
  2. fingermouse
    fingermouse thats me
    3,995
    111
    how much were they out of interest as I may change mine when I do the suspension
  3. Sandip
    2,440
    91
    cheap, £30 thats two mount's and two bearings from the dealers :icon_thumright:
  4. s3jon
    s3jon New Member
    i paid £18 from gsf for mine.:cool:
  5. jonS3
    jonS3 Member
    719
    were they genuine audi parts? I've bought top mounts from GSF before for a mk3 golf gti and they useless, ended up taking them back and buying genuine.....
  6. Sandip
    2,440
    91
    mine are genuine audi parts
  7. CLS3
    CLS3 Every penny goes on the Audi!!
    100
    I know this is dragging up and old thread but I believe this trait of the S3 hinders a lot of people so...
    exactly how hard is it to replace the top mounts. Is it a case of dropping the strut down and sliding old mounts and bearings off and sliding new ones on?
    Thanks for any help Chris :o.k:
  8. Ian W
    Ian W Active Member
    1,058
    12
    Remove strut, strip strut, replace the mount and bearings, refit !
    Not difficult but a bit time consuming and you need the correct tools.
  9. CLS3
    100
    good good, thanks for that.
    And a little off the subject Ian, how do you find your B8's and H&R springs? they could well be my next addition to the S3. do they ride quite harshly with the 18" RSTT's?
  10. jesters3
    jesters3 Active Member VCDS Map User
    1,516
    Anyone got the part numbers?
    Also I take it this was for the front only; how about the rear what is needed for these; if any?
  11. Ian W
    Ian W Active Member
    1,058
    12
    Can't recommend them enough, car feels like a go kart now, everytime I get to a roundabout I seem to build up speed and throw it in !
    Well worth the money IMO, standard stuff doesn't come close !
  12. vanilla_ice
    vanilla_ice Member
    697
    22
    Has comfort been comprimised by the B8's to any great extent?
    ICE
  13. Ian W
    Ian W Active Member
    1,058
    12
    No, not enough that I notice tbh.
  14. CLS3
    100
    Thats good to hear, my S3's ride is as hard as nails with the RSTT's and Roll Bars on.
  15. vanilla_ice
    vanilla_ice Member
    697
    22
    ICE
  16. Nilz
    11,329
    876
    Sandip, was it hard to replace the top mounts, how long did it take and could you do it yourself??
    I have just replace my front ARB Bushes, but still getting the noise, so i think this may be the next step....
    Nilz
  17. vanilla_ice
    vanilla_ice Member
    697
    22
    ICE
  18. fingermouse
    3,995
    111
    its a couple to 3 hours job if you are geared up and stuff comes apart ok, you need a 21mm socket that you can hold with a spanner while you put a 7mm allen key down the center. think other tools required are 18mm, 16mm 10mm spanners/sockets and a splitter or chisel to aid removal of the shocker from the bottom clamp.
    oh and spring compressors if its std suspension.
  19. Nilz
    11,329
    876
    Cheers dude, will have a look into that when i get a chance :)
