S3 tickover question
simon-s3 Feb 22, 2008
  1. simon-s3
    simon-s3 Member
    126
    Are these engines normal a bit "clicky" at tickover ?
    not sure if it is tappetts or noisy injectors. at tickover it has this fast, regular clicking (when stood outside the car in front of it, not sat inside), but if I raise the revs to 2000RPM all is as smooth as can be. Sat inside it sounds smooth and quiet.
  2. JohnS3
    JohnS3 Active Member
    3,032
    Sounds normal to me. Anyone else?
  3. simon-s3
    simon-s3 Member
    126
    that makes me feel a little better already. It only has 7000miles on it. My Imprezza I had a couple of years ago was a bit like this and that was noisy injectors.
  4. klauster
    klauster Well-Known Member
    1,188
    112
    ruff as a badgers ass at tickover the S3 engine, sounds much better with revs..... well mine did anyway
  5. julians
    julians Member
    312
    S3 sounds like a diesel at idle, so its probably normal, if not just drive it until something significant actually breaks then take it back and get it fixed under warranty.
  6. simon-s3
    simon-s3 Member
    126
    thanks, feleing better all the time. So it's normal, Drive it like I am trying to break it and get it fixed under warraty when it does. Sounds like a fun plan. ............I will still warm it up first though
  7. DemianM
    DemianM RWD sucks!
    175
    Same with mine, my garage is very closed and small and when you hear it bouncing against the walls it sounds terrible!
  8. jamiekip
    jamiekip Guest
    Mine's the same, I think it's something to do with the FSI. Nothing to worry about.
  9. t&biskits
    t&biskits it`s all black
    50
    i`ll go with that too, mine sounds like **** at tickover. a friend did once ask if it was diesel!:faint:
  10. Oli.
    Oli. Member
    562
    10
    Its normal - Its just the injectors. My GTI sounded **** as well!!
  11. S3-N
    S3-N ?
    263
    another diesel sounding S3 here
  12. consilio
    consilio Up the owls!
    666
    Same here. But it sounds amesome for a 4 pot when doing anything above 2k.
    Love the whinning noise and exhaust it gives when you ease off the throttle
  13. richs2891
    richs2891 I cant spell !
    441
    Yes mine sound rough / diesel like when first start up but I dont think it sounds that good for a 4 pot - I miss the noise my old Scooby made - much better than my current S3 !
    Richard
  14. consilio
    666
    Yea i know what you mean, if you like that sort of thing. Scoobies as a bit much for me, too boy racer
  15. JamS3
    JamS3 Active Member
    2,258
    24
    Its normal! Its due to the high pressure FSI injectors and that's the noise you can hear. It also has a secondary injection system that operates when the engine is cold.
  16. simon-s3
    simon-s3 Member
    126
    Cheers, I feel fine about it now. All these S3's sounding the same says it's normal to me.
