S3 Suspension noise
bdavbdav Sep 10, 2011
  1. bdavbdav
    bdavbdav Member
    93
    Hey,
    Just picked up an S3 with about 600 miles on it a couple of weeks ago - 2 tiny things I've picked up on that worry me slightly - over speed bumps etc theres a noise i can hear off the front suspension - almost like theres something a bit bigger than a leaf stuck in it brushing up against rough bodywork inside the wheel well.
    Also, when turning either way, I can feel the slightest vibration through the footrest - nothing when going straight, and like I say it is only just perceivable.
    Should I be worried about either of these?
    Cheers,
    Ben
  2. Boydie
    Boydie S3 8V DSG VCDS Map User
    3,488
    633
    Like a "squish" noise going over ramps - this is normal.
    Don't know what the second issue could be - get under the car and check for wear but if it has warrenty then get it into Audi
  3. paddy
    paddy Audi=No fault code, no idea Team Ibis Audi S3 Black Edition DSG
    5,366
    203
    Check your tyres, sounds like one could be a bit out of shape. I had that vibration when not straight after i hit a pot hole and when i jacked the car up and span the wheels i had bent the reinforcing wire in the tyre. Check the pressures too
  4. s3dave
    s3dave TFSI Hybrid Supporter
    10,110
    736
    I dont know how old your car is ben, but worn top mounts on the front suspension legs can make those noises...
  5. bdavbdav
    bdavbdav Member
    93
    Brand new effectively - Its very subtle though - I can only hear it with windows down and radio off!
  6. bagey
    bagey aud you do !
    198
    is it just one side ? if so try changing wheels round as im having the same kind of problem and it seems to be an alloy/ tyre issue as the noise has switched sides now
  7. Ads
    Ads License to drive
    8,230
    612
    The brushing noise when going over bumps I don't think is "normal".
    I know exactly the noise you are talking about... sort of a sandpaper scrape noise?
    My first A3 did it, but my second one didn't.
    I don't know what the cause was though because I sold the car, but it never got any worse, just stayed the same.
    Sorry, not very helpful, but just to let you know it's not a feature of all 8Ps.
  8. bdavbdav
    bdavbdav Member
    93
    Yeah that sounds like it - it's not a nasty noise as such, just seems like it probably shouldn't be there.
    I've tried bouncing on both sides at the front and can't recreate it when static - is there anything which could possibly rub on the wheels to check?
