S3: Surging on Part Throttle. N249?
AL_B Apr 4, 2005
  1. AL_B
    AL_B Well-Known Member Team Daytona Audi S3 DSG
    1,769
    209
    Hi guys,
    Having had my spark plugs changed, in the hope of fixing the hesitation (split-second loss of boost) that occurred at about 3800rpm. And it did seem to fix that problem.
    My car now has another problem....a surging or running-on feeling on part-throttle. It also seems to get confused in high-revs throttle-on-off-backon situations.
    My intial thoughts were, it has to be the DV, and it could still be that. But browsing the internet and talking to my dealer, seems to suggest it could be the N249 valve.
    Paul-S3 - I saw your post on tyresmoke about the N249. What caused you to think there was a problem? Was it surging?
    Anyone else experienced this and know the exact cause/solution?
    AL
  2. Khufu
    Khufu Well-Known Member
    5,704
    31
    I dont know if it helps but mine does it too occasionally when you take your foot off the throttle it seems to surge a bit and I dont have a turbo...
  3. AL_B
    1,769
    209
    Cheers Khufu, but I think I may have found the cause of the problem.
    There could still be a problem with the N249 or DV, but I have found a hole in one of the tubes going into the N249. See pics...
    Got the idea to check this from Wak's site...
    http://www.wak-tt.com/warnings/n249pipe.htm
    (nice one Wak)
    AL
  4. AL_B
    1,769
    209
    Hole is caused by the electrical connector rubbing against the tube over the period of years.
    How the "mechanic" did not spot this when the plugs were changed I do not know.
    AL
  5. Khufu
    5,704
    31
    Glad you found out the cause. Let us know if repairing it rectifies your problem.
  6. olekvi
    olekvi Member
    68
    [ QUOTE ]
    Hi guys,
    [/ QUOTE ]
    I'm having a similiar problem with my car now; could you please describe how 'you felt it'? (full throttle, part throttle?)
    regards
  7. PaulRS3
    PaulRS3 Well-Known Member
    1,229
    156
    "Paul-S3 - I saw your post on tyresmoke about the N249. What caused you to think there was a problem? Was it surging?"
    hi mate, ive never had a problem with this valve, i just posted a pic so people could see where it was located.
    common faults are its been unplugged, pipe popped off or a split like Waks site.
    the N249 controls the DV.
    N75 controls wastegate.
  8. AL_B
    1,769
    209
    Cheers Paul.
    I temporarily put some insulation tape around the hole this morning and there has been an improvement. No hesitancey in on-off-backon throttle situations. There may still be a little surging, not sure.
    Still going to get the dealer to do a diagnostic, replace the pipe and possibly the N249.
    AL
