S3 stage 2 without changing air intake???? just upgrade panel filter?????
NIC1985 Mar 29, 2013
  1. NIC1985
    NIC1985 New Member
    25
    Im upgrading to a Cobra turbo bk exhaust with Decat and non res bk box and Hopefully stage 2 re-map.
    BUT i don't want to change the air intake! will I be able to achieve stage 2 with the standard air intake system??
    Ive heard you can get heat soak if you upgrade to a cone filter!!! has any1 heard of this??? apparently Heat Soak is when warm air is drawn in through the cone filter???
  2. S3Alex
    10,832
    4,830
    It is possible...I did it,but frankly it's not the best way to go.
    The stock system does strangle airflow at peak rpm and may throw errors or misfires,but yes,it can be done,at STg2....I wouldn't try it at Stg2+.
  3. NIC1985
    NIC1985 New Member
    25
    what do ya reckon change the air intake then??
    I dont like the cone filters, There must be something thats bigger, id like to get something that really sucks the air in from inside a unit like the standard air intake, with a good flow of cold air there must be one designed already????
    maybe you could attach a small intercooler mounted behind the grille with hoses that feed back to the air intake that would be perfect for me
  4. S.
    S. Save the manuals Team Ibis TFSI Owners Group Audi S3 quattro Manual
    2,061
    572
  5. MartayMcFly
    MartayMcFly Booooooost VCDS Map User Gold Supporter
    2,766
    355
    I'm pretty sure heat soak is when the intake channel isn't properly shielded and the air warms up before entering the engine. The idea behind a cold-air intake is that you suck air from the front of the engine bay, or from behind the fog light, so it's not being affected by the warm air in the engine bay. A good thermal insulator around the pipe will limit the soak effect. I think a dedicated intercooler for a cold air feed might be a bit much, also not sure what you plan to use to cool the air... why not just channel the cooling air directly?
  6. box500
    box500 Member
    163
    I'm running revo stage 2 with just uprated panel filter if it helps..
  7. voorhees
    voorhees Moderator Staff Member Moderator Team V8 Audi S5 s tronic
    16,242
    2,066
    A few induction kits on the market take your pick evoms,itg,revo
  8. NIC1985
    NIC1985 New Member
    25
    forced cold air induction kit for me I think, dont want a crappy cone filter, want a direct feed from cold air on tap
  9. garythedrummer
    garythedrummer New Member
    23
    Hi, i have stage 2 APR with downpipe and standard air filter. I have been experiencing missfires around 3k and latter around 6k. i presumed it was due to fueling issues or needing new spark plugs, however S3Alex has now got me thinking that my problem may be due to to the standard air box.
    The missfires relly ruin the power delivery and the overall driving experience so i intend to look further into wether the missfires are caused by the standard airbox Can you shed any more light onto this issue S3alex?
  10. r7ano
    r7ano Race Tech
    31
    Hi I am running st2 with standard filter and it was mapped with a stock exhaust with pre cat removed and no problems at all!
    MRC map 330bhp 475Nm on RR and cool plugs from S2
  11. mjr901
    mjr901 Guest
    Forge twintake is the pup then.
  12. Acheron
    Acheron Active Member
    271
    30
    I ran stage 2 with no intake for a few months (since Revo lists it as an optional mod at this stage) with no issues to speak of. I've even had my stock airbox on recently with stage 2+ for a few days (after a service) and while peak power was definitely not where it was with my EVOMS the car did not feel like it was labouring or running any worse.
