S3 sportback side skirts install instructions?
emeraldA3guy Feb 6, 2010
  1. emeraldA3guy
    emeraldA3guy Member
    131
    DOes anyone have installation instructions for the S3 skirts for the sportback?
  2. emeraldA3guy
    emeraldA3guy Member
    131
    bump
  3. emeraldA3guy
    emeraldA3guy Member
    131
    do i need to drill holes on the bottom of the car to fit the skirts?
  4. Khufu
    Khufu Well-Known Member
    5,704
    31
    No, I read that you just bond the underside with a bonding sealant . I have skirts to fit myself but i'm waiting till its a bit warmer.
  5. robby
    robby Active Member
    579
    69
    How much are the S3 or Votex skirts for a 3 door? i guess they come in primer?
  6. aristides
    aristides Member
    550
    I`ve heard they are a lot of work and big cost
    I got some instructions, in a pdf somewhere but they are in german.
    Will look them up for you
  7. A3TDI2.0
    A3TDI2.0 Member
    50
    I had Votex sideskirts put on my Sportback, cost me £150 for spraying and fitting.
  8. robby
    robby Active Member
    579
    69
    Do you remember how much the skirts cost?
    I had the full Votex kit on my last A3 but just need skirts on this as it has the S-Line kit, skirts will finish it off nocely
  9. emeraldA3guy
    emeraldA3guy Member
    131
    I bought the screws for the kit also need to know where that goes?
  10. chris1988brown
    chris1988brown Member
    575
    i would just bond them on mate much quiker and easier, plus you dont wanna drill your sills and risk them gettin water in them causing rust. i'll be bonding my s3 skirts
  11. Khufu
    5,704
    31
    Since the weather was nice, I took the chance to test fit mine. You need to heat the scuff plate & rear quarter to soften the glue & then gently pull off. The door trim has 2 screws & then you slide the trim towards the rear of the car. The caps on the wings have a plastic spring clip in behind them so you need to remove the arch liner a bit to get in to the back of it & then squeeze the tabs together to remove.
  12. robby
    robby Active Member
    579
    69
    Colour match isn't great :)
    So do you remove the origional plastic part from the bottom of the doors and the rear wing and replace the door ones with new parts supplied?
  13. Khufu
    5,704
    31
    yes, as I said above, you remove the rear quarter trim by heating the glue and pulling off. Same with the sill scuff trim (even heating it still ruined in my case LOL). The door trim unscews & slides towards the back of the car. The front cap is unclipped from in behind the wing so you need to remove the wheel arch trim liner.
  14. emeraldA3guy
    emeraldA3guy Member
    131
    does the skirt clip into the part where you take the sill off?
  15. Kev
    Kev New Member
    Khufu: Great job mate!:hubbahubba:
    Please, can you upload some pictures of the whole car? Do you have the S3 Kit installed? (I mean front and rear bumper also) I am looking for pictures of an A3 with Sline kit plus S3 side skirts installed to check the height diference from floor beetwen bumper and side skirts.
    I have an A3 sportback restyling.
    Thanks in advance
  16. N8
    17,163
    719
    Can't wait for my S3 SB Skirts to go on, anyone got full price, as I got majority of part no.s ain't priced it all up..
  17. A3TDI2.0
    A3TDI2.0 Member
    50
  18. emeraldA3guy
    emeraldA3guy Member
    131
    i think my price was around ~700usd. No door blades.
  19. robby
    robby Active Member
    579
    69
