S3 Spark Plugs - Stage 2+
S3RYE Oct 4, 2011
  1. S3RYE
    S3RYE Interior Next!!
    3,448
    70
    Hi All,
    As you know been running stage 2+ for around 10,000 miles.
    When it was taken from stage 1 to 2+ i had the plugs and coilpacks changed over to fresh OEM ones as reccomended by AMD Essex. The ones in there were fecked and gave up the minute it went 2+. Now i had previously seen a lot of talk about colder Iridium plugs but AMD said there was no need (not sure why)
    My car has developed a major misfire/stutter and im thinkin its got to be the plugs again as it feels exactly how i did last time they went. I have two questions do i go for another stock set or colder ones?
    Also who has the OEM plug part nos so i can get them from Euro car oarts or the like?? or if you have a different suggestion of plug which ones?
    Thanks in advance and quick helped will be much appreciated!!
    Rye
  2. jsws3
    jsws3 Member
    440
    Send edition 30 p a pm he gets coilpacks and plugs cheap I had 4 plugs and coilpacks for £90
  3. S3RYE
    3,448
    70
    phils a top man! sorted me out a few times. Thing is i need the fast like today and by the time i drive over to west to meet phil i may as well pay more and get them local! Will i need new coilpacks too?! they were done 10k ago?
    cheers though bro!
  4. jsws3
    jsws3 Member
    440
    Have you got vagcom if so you could do some data logging to see what coilpacks need replacing .
    I'f not and it was me I would change all four to be on the safe side.
  5. S3RYE
    3,448
    70
    No vagcom! will the coilpacks needs replacing though after 10k? :unsure:
  6. warren_S5
    warren_S5 Moderator Staff Member Moderator VCDS Map User
    7,210
    2,483
    Coilpacks shouldn't need replacing.
    Take the plugs out and clean them GENTLY with a bit of electrical contact cleaner and an old toothbrush. Should keep you going until new ones arrive if it's just a bit of plug veneering.
    One of the usual suspects did data logging with plugs and Iridium 7's gave better general running conditions than OEM plugs. Only issue you will suffer is if you do lots of short journeys they may cack up quicker.
    In principle I agree with AmD that OEM should be fine, but the 6 temperature plugs don't seem to last any better. Supposedly VAG group are running a revised plug in these engines now, so may just be worth trying those from main dealer; about £40.
  7. S3RYE
    3,448
    70
    Thanks War!
    Ill call them now, see if i can collect a set tonight. Get them installed tomorrow!
  8. S3RYE
    3,448
    70
    could someone give me the part no for the S3 plugs? its a MY09. Audi want£53.52 inc vat for 4x plugs is that te right sort of money? or much cheaper at Euro car parts?
  9. S3RYE
    3,448
    70
    thanks for all the answers guys! NOOOOOOOOOOOOOOOOT!
    youll be glad to know its all sorted.
    New plugs from Audi (got ass raped £53)
    Misfire/hesitation = GONE! :o.k:
    oh and i threw the boxes away without looking at the part no :keule:
  10. S.
    S. Well-Known Member Team Ibis TFSI Owners Group Audi S3 quattro Manual
    1,975
    537
    yes..but for how long?
  11. S3RYE
    3,448
    70
    hopefully another 10k! although it wiull be in for service in 5k haldex change, oil service an all that. So will prob have another new set then. Im not being funny but for £40-50 its worht changing them often. I think the fact i do lots of small journeys where the car doesn't get fully warmed isn't helping!
  12. S3Alex
    10,585
    4,653
    Interesting.....the advice I've had from both AMD and VWRacing is to use stock plugs,and change every 5000 miles or so.
    My car has been at Stg3 for around 12 000 miles,and Stg2+ for nearly 20 000 miles before that,with no problems related to the plugs.....the only misfire issues we had were down to the stock intake strangling the airflow,and once that was removed(at 2+),there have been no further problems.
  13. S3RYE
    3,448
    70
    strange, my car munches plugs like a crack whore
  14. jsws3
    jsws3 Member
    440
    My mrs does 8 miles a day from home to work and we have never had any coils or plugs go down on us and if been at stage 2+ for about a year .
  15. S3RYE
    3,448
    70
    im obviously different to you all.. maybe i drive harder than your mrs? or im just an unlucky pr1ck with a lemon
  16. S3Alex
    10,585
    4,653
    Who knows.....it may be individual cars and settings,and a host of other things,but as I said,mine has behaved itself very well,and there are no misfires if the plugs are changed every 5 000 miles or so.
    I've certainly found it easy to tell when a set are on the way out,as it does develop a progressive softening and small misfire under full throttle when they're really done......but the OEM ones are fine with 2 bar peak boost......WMI and more power on the way.
  17. S3RYE
    3,448
    70
    its probably cause i left it so long to change them, a pure oversight! it was around 11k! so there your answer probs! it went exactly how you said! softened, then misfire!
    cheers Al!
    nice to see your taking your car to the next step! have to get a run out in this sometime before you let it go!
  18. S3Alex
    10,585
    4,653
    I left a set for 10 000 miles and found exactly this problem......just a worsening misfire and softening performance,which a new set cured.
    Mine is almost ready after having a bottom end build(pistons and rods) as well as a USP Motorsports auxiliary fuel pump,turbo heat jacket,few BSH bits,and an AEM water injection kit.....a friend of mine on another forum has a mate getting over 530bhp on this sort of setup,so my fingers are crossed.
  19. Paullie
    Paullie Banana Menace! VCDS Map User
    2,076
    288
    Sorry I didn't see this earlier on Ryan :( . Part number is PFR7S8EG (NGK Platinum OEM plugs)
    PFR7S8EG | eBay
  20. S3RYE
    3,448
    70
    thanks Paulie, thats interesting. The Plugs i bought from Audi are Bosch? :wtf:
  21. S3RYE
    3,448
    70
    look, just make sure i get to experience this at some point Al!! sounds awesome!
  22. S3Alex
    10,585
    4,653
    Any time you can get to one of AMD's Open Days,or perhaps the Inters next year.....or something I can get to,you'd be more than welcome.
