S3 SPACING AND DROP ADVICE GUYS!!!
S3TURBS Mar 6, 2013
  1. S3TURBS
    S3TURBS Member
    50
    WIETECH BYKW 20MM DROP BACK 25MM FRONT IS THE KIT I BOUGHT,
    BACK WHEELS ARE STANDARD RIMS, BUT SPACED OUT 15MM....FRONT NO SPACING.
    WILL I GET THE CLEARANCE ON THE BACK? PLUS DO YOU REK IT WILL SORT OUT THE REVERSE RAKE!!
    SORRY FOR CAPS DOING A SPREADSHEET IN WORK :)
    THANKS GUYS
  2. jimojameso
    jimojameso Active Member Team Nardo Section Mod Audi RS3 TTRS
    382
    175
    43
    You might have to change the rear spacers down to 12mm as i think 15's might rub a little. You can try taking the rear screw out the arch. If its a sportback you will have to file the tab down aswell. :)
    On my sportback i have 11mm spacers on the back and i had slight rubbing on large potholes/bumps but once i adjusted the tab i have no rubbing at all.
  3. Stuwhipps
    Stuwhipps Member
    50
    I have 15mm spacers on the rear and 10mm on the front on the standard s3 rims with s3 brakes and no rubbing or issues at all, once lowered the clearance still looks like it would be ok though ?
  4. S3TURBS
    S3TURBS Member
    50
    Cheers L5, what springs you on mate?
  5. Stuwhipps
    Stuwhipps Member
    50
    None yet but will be H&R (as that seems to be the spring of choice if not going the coilover route) and as you can see (well sort of) from the attached picture there is room between the rim and arch even with a drop as they are not totally flush.
    Just thinking though your wheels are a 19 arent they ? If so that blows my theory out of the water ?
  6. leeds2592
    leeds2592 When I grow up, I want a 964!
    1,399
    222
    It all depends on how low you go.
    A lotof people get some rubbing on 12mm spacers when lowered so it can only be worse with 15mm.
  7. jimojameso
    382
    175
    43
    I'm on H&R's and it was only on really big bumps i got rubbing.
  8. Stuwhipps
    Stuwhipps Member
    50
    With spacers or without ?
  9. jimojameso
    382
    175
    43
    With 11mm spacers on the rear. But i have a sportback if that makes a difference.
