S3 Slow starting issue
s3_kev Feb 15, 2014
  1. s3_kev
    s3_kev Stage2'd!!!!!!
    2,002
    23
    Hi guys my 57 plate BHZ S3 seems to have a slight starting issue at times when its cold, its seems to have to crank over a little more before it fires, once its warm it goes almost at initial turn of the key.
    Also when its cold it doesn't run as smooth as when its warm it just feels a little lumpy?
    I've changed Dv, PCV already and removed inlet manifold and cleaned the inlet ports.
    Any ideas guys?
  2. warren_S5
    warren_S5 Moderator Moderator VCDS Map User
    7,210
    2,488
    Spark plug carbon build up / end of life?
    What plugs are you running?
  3. s3_kev
    2,002
    23
    Might whip a plug out next but I changed them when I 1st got the car in September last year there OEM from Tps so should be ok
  4. warren_S5
    7,210
    2,488
  5. s3_kev
    2,002
    23
    No misfire just doesn't seem to run as smooth as I'd like when cold as said once warm it runs sweet
  6. warren_S5
    7,210
    2,488
    May also be worth checking the MAF and the cam follower.
  7. s3_kev
    2,002
    23
    I've seen a lot of threads containing comments about the cam follower, might look into this not sure where it's located with out looking it up.
    I do have a spare mass air flow to try if it comes to it just haven't bothered yet lol
  8. voorhees
    voorhees Moderator Staff Member Moderator Team V8 Audi S5 s tronic
    16,249
    2,072
    I do hope its not the cam follower
    warren_S5 likes this.
  9. warren_S5
    7,210
    2,488
  10. s3_kev
    2,002
    23
    Cheers for the thread, reckon I may change the cam follower as precaution even if it seems fine.. Cheers for the heads up :)
  11. Turbo jay
    Turbo jay Leather repair specialist
    577
    69
    Could also be coil packs, I have this issue also when starting from cold, fine once warm, my car is in Audi Tuesday for new coil packs so ill report back once they have be fitted hopefully this solves the issue.
  12. s3_kev
    2,002
    23
    Are the coil packs warranty? I no they did them under warranty when I had my 8L as they are so common
    cheers
  13. XFi
    XFi In need of a V8.
    491
    47
    Not on the 8P's, I've changed coil packs and it didn't help my issue which was bad idle/misfire. I then got an emissions light with bank 1 running rich because the seal in my HPFP had gone. New Loba pump and all is fixed as far as the idle issue goes. I think the cold start issue is just a TFSI engine qwerk.
  14. warren_S5
    7,210
    2,488
    Some cars did get them as a free replacement, but my old '07 wasn't in the allocated batch that Audi deemed needed them. Worth a shot though.
  15. s3joe
    s3joe Active Member
    588
    92
    Mine has just had the coil packs done by Audi for free I was going to ask about this as mine is doing it as well and I have done the cam follower as well
  16. Granta
    Granta Active Member
    294
    62
    I have the exact problem in start up in the morning, but only on idle, just really lumpy, as soon as you start driving it clears itself. I have called audi to see if there is any outstanding recalls on mine and they said no, still on original coils.
  17. warren_S5
    7,210
    2,488
    Check your PCV
  18. Granta
    294
    62
    I'm going to spray brake cleaner on it and see if it picks up..
  19. s3_kev
    2,002
    23
    These latest posts have now baffled me haha, think I'm going to change the cam follower first and if the fault persists then I will go back to Tps for a replacement PCV.
    Glad I've asked the question now though seems to be a fault and not me thinking there's one.
    Cheers guys
  20. Granta
    294
    62
    Mines on 50 k so going to do cam follower and see from there, might also do PCV delete if it carries on. apparently had spark plugs at 40
  21. s3_kev
    2,002
    23
    Any luck with your visit to Audi?
    I have fitted my cam follower and it does seem to drive smoother however I'm unsure if it's 100% fixed tbh
