S3 Short Shift
DPM Nov 10, 2006
  1. DPM
    DPM Site Sponsor Site Sponsor
    5,063
    224
    Has anyone fitted a short shift to there S3? I'm thinking of giving the Diesel Geek one a go to see how it feels but was just interested in anyone else's opinion that's got one fitted?
  2. Peloton
    Peloton Member
    354
    I'm sure Defratos has one fitted. He's got a bit on his website about it.
  3. madvw
    madvw Active Member
    2,489
    have you had a look into fitting an OEM TT one? they are shorter than an OEM S3 one. A dieselgeek may seem extreme on an s3.
  4. Ess_Three
    Ess_Three Active Member
    5,383
    Try to find someone with one to try first...
    I tried a Neuspeed short shift and I hated it.
    The S3 'box isn't the most slick ever produced and it just made it worse...
    And S3 'boxes have soft-as-***** 2nd to 3rd syhchros (as will all VAG gearboxes) and adding a short shift can increase the change of rushing the gearchange and wrecking the synchro.
    I managed to 'harm' my 2nd to 3rd synchro without a short shift...so with one it would have been gearbox rebuild time by now....that is assuming you want a short shift to change gear a bit quicker?
  5. Defratos
    Defratos You’re Dethpicable!!
    2,232
    I've got the diesel geek one installed, imo I like over the nuespeed and oem, I've tried the nuespeed but it just felt too clunky, the geek one felt really smooth, but I haven't tried his new ones (I had the slightly older version if you take a look at my website). Anyway I'd agree with Ess with this one, even though I've got a short shift, when it comes to shifting quick i can feel it harms the engine at times, but only when it's silly shifting, otherwise I'd say go for it, would be nice to see how someone else finds it :beerchug:
  6. DPM
    5,063
    224
    Hmmm... undecided now!
  7. tommo-turbo
    tommo-turbo Member
    164
    I took delivery of an EIP short shift with reduced side to side from The Phirm. Went to fit it and it was the wrong type for my car. My pre-facelift requires the ball type linkage and they sent the pin type of the facelift model. Gotta send it back to the States and wait for the right one to turn up. Not of much use, but kinda related and I needed to vent...
    *and calm*
  8. madvw
    madvw Active Member
    2,489
    has nobody ever tried the OEM TT one?
  9. Defratos
    2,232
    If you've got a bit of £ and it's not much then I'd say go for it mate, personally I think it's well worth the money and I've had it for nearly 2 years and nothing bad so far :drag:
  10. mattyboy199
    mattyboy199 Well-Known Member
    1,890
    29
    I m amazed at this i thought it would be first on the list unless its that hard to do or exspensive ?
  11. DPM
    5,063
    224
    :iagree:
  12. leecs3
    leecs3 thinking about stuff
    604
    Price and part number anyone? let's give it ago.
