S3 service book and start/stop
geefunk1978 Dec 13, 2013
  1. geefunk1978
    geefunk1978 Well-Known Member
    660
    408
    For those of us lucky enough to already have our S3's I have a couple of queries.
    I didn't get a service book to stamp in? Dealer said it's all done digitally now, anyone else not got a book?
    My start/stop hasn't worked once since I had the car, now should I be worried something is wrong or not? I turned everything that uses power off (mmi, climate etc) and it still wouldn't work! I've an s tronic by the way. Any ideas people?!
    G
  2. cuke2u
    cuke2u Well-Known Member TFSI Owners Group Audi A4 saloon S-line owners group
    6,569
    1,996
  3. PilotAudi
    PilotAudi New Member
    2,352
    479
    The Stop start worked fine in the S Tronic I had yesterday!
  4. pat15312
    pat15312 Well-Known Member
    530
    252
    Start stop was on by default when I got mine. Might be worth checking the menus under Car to see if there is an option to permanently turn it off.
  5. Johnnyb
    Johnnyb Well-Known Member
    734
    301
    If anyone can confirm if this is possible that would be a great help, it's a total pain in the ass trying to remember to manually turn it off everytime i get in the car!
  6. cuke2u
    6,569
    1,996
    Lets not hijack 'G's' post with questions about whether the start/stop can permanently be disabled when it probably can't be..
  7. Johnnyb
    734
    301
    Your post would hold more weight had it ended in "when it definitely can't be" It in fact may well be the reason G's start / stop is not working if it has somehow been turned off through the MMI..Just sayin'
    RedDejavu and PilotAudi like this.
  8. cuke2u
    6,569
    1,996
    The best thing to do is to search the 8v forum first before asking. I am sure this question has been covered before. If it hasn't then start a new thread as then it will get more attention instead of being buried within someone else's...
  9. Johnnyb
    734
    301
    Searched a few days ago and couldn't find an answer on it..I know you have got OCD about these things, but i felt it could have helped / related to geefunk's query..
  10. steeve
    steeve Well-Known Member TeamMisano Team Ibis Audi S3
    2,718
    1,561
    There is still a service book, it doesnt have spaces for stamps as that is done digitally, but you should have the standard Audi book.
    It's called " Audi Service Schedule" "For vehicles with Digital Service Schedule"
    number is 141.563.8S2.20
    As far as stop start, make sure it's enabled first then it will only work when all the parameters are met. My A3 was intially reluctant, but as the miles have accrued it works more often. Your handbook lists all the criteria.
    I
  11. Battlekrapz
    Battlekrapz Active Member
    418
    241
    43
    You lucky sod if your start/stop is malfunctioning! I wish mine was!
    DrTS and Johnnyb like this.
  12. steeve
    2,718
    1,561
    You can switch it off.
  13. Johnnyb
    734
    301
    Permanently? There is a switch below the air vents that switches it off once the car starts, but then it resets everytime you turn the ignition off, so have to keep turning it off everytime the ignition is turned on..If there is a way to disable it through the MMI or something then that would be great and would possibly be why geefunk has yet to see it working in his car..
  14. h5djr
    9,463
    1,770
    I don't think anyone has yet come up with a way to permanently switch off the Start/Stop system even using VCDS. The dealers will not do it, even if the can, because they say it would mean the car would no longer match it's EU Type Approval and the car would then be illegal to drive on UK roads.
    The Golf VII DSG that I drove for the day yesterday needed quite a bit more pressure on the brake pedal to get the engine to cut out that on my current s-tronic A3. I was easy to stop at a junction and hold the car on the brake without the engine cutting out.
  15. jet_andy
    jet_andy Active Member
    168
    30
    It cannot be permanently disabled by the driver and as previously stated the dealer's won't even if they could. If it were permanently disabled the cars CO2 rating would be invalid and therefore it's tax rating.
  16. Johnnyb
    734
    301
    Thanks for the clarification! geefunk - i'd give the dealer a call, although i'd be happy with it off just like Battlekrapz! I'm off to invent a rigid device that attaches to one's left shoulder so that when you get in the car it presses the disable button for you...
    GRE57Y likes this.
  17. geefunk1978
    660
    408
    Hmm I've got that service book so that's definitely right if it's all digital nowadays.
    As for start/stop it's activated but always comes up with an A with a slash thro it on the display when I stop. Might have to ring the dealer to see what they say, it'd be nice to know it works tho! Might save me some fuel as it's averaging 22mpg at the mo on my daily commute, but then again it is only 2.5miles to work lol
  18. Daggerit
    Daggerit Well-Known Member Team Floret Silver TFSI Owners Group Team V6 Audi S4 quattro Audi Avant Owner Group
    1,875
    665
    Not an S3 but I know that my car has to be warm and all sorts before the stop start will work. In addition things like having the steering turned near the stops seems to stop it turning off too...
  19. GNJ_Motorsport
    GNJ_Motorsport Site Sponsor Site Sponsor
    660
    188
    43
    I'll be doing all I can to find a way of turning this **** off with VCDS when ours comes so if/when we find out I'll put a tutorial up!
  20. CraigI
    CraigI Well-Known Member
    1,484
    1,216
    500 miles in and my start/stop has been working well (if that's how you consider it) since day one.
  21. Dylock
    Dylock Active Member
    271
    71
    I find the start/stop works perfectly and I like it. With my s3 stronic I find that I'm the one controlling it not the other way around. Ie come to a stop with a light peddle press and car is still running. Push it harder and the engine stops. So it stops when I want. I don't have hill hold and from what ive read that changed things.
    If your journey to work is only 2.5 miles I would not expect it to work. Have you tried a longer journey and then to be sure turn all heaters ect off?
  22. geefunk1978
    660
    408
    Yeah it's had a few long journey's too and I tried turning everything off and still didn't work. Very odd as no one else seems to have any problems!
  23. Lock & Load
    Lock & Load Member
    46
    20
    See if you can reset your ECU this may restart the stop / start function
  24. geefunk1978
    660
    408
    That will have to be a main dealer job won't it?
  25. Lock & Load
    Lock & Load Member
    46
    20
    No not really some one in the Audi community should know how to reset the Ecu
  26. Scotty2011
    Scotty2011 Active Member Team Glacier Audi RS3
    287
    168
    43
    The start/stop doesn't work properly until the engine is up to a certain temperature and the temperature inside that car is at what you have set it. So if you crank up the temp in the car it will stop working until it reaches that temp inside. Hope that makes sense.
  27. cuke2u
    6,569
    1,996
    Start/stop systems use various sensors to dictate how the system performs. Internal/external temp, CC settings/ engine temp and the battery voltage. Start/stop systems also tend to have a different battery and alternators to cars that do not have the same system. I've had mine start the engine up automatically when the cabin temp started to rise, however it has stopped working completely now as I only perform short journey's and the battery voltage isn't high enough. This is on my Focus of course so I am interested to see how the system works when I get my new Audi...
  28. JohnM100
    JohnM100 #teamSepang VCDS Map User Gold Supporter
    952
    394
    Start/stop won't work until the car is warm and that has been posted earlier. It would explain the lack of start/stop on your commute.
    Separately, lots of short journeys in a row will hit the battery and one of the (several) other criteria for Start/Stop is a charged battery. Perhaps the battery is still charging on the longer journeys?
    John.
  29. geefunk1978
    660
    408
    It hasn't worked since I picked the car up and that journey home was 90 miles and I had to stop at traffic lights/roundabouts so doesn't make any sense. I think there must be a fault on it. Will ring dealers and find out...
