S3 seems to run bad once warm ! And won't start ??
motfree Nov 9, 2010
  1. motfree
    motfree Member
    464
    Had a few problems with my s3
    Anyways replaced mass airflow and cam shaft sensor but now it seems to be cutting out once warm then will not start again .. Last time came up with the above faults but these have been replaced .. But before I put the new turbo on the car wouldn't hesitate to start ( didn't have boost mind ) .. My mates don't have a clue neither do I and I'm loosing patience haha any help would be great :)
    Ps live in north west ;-)
  2. 1animal1
    9,978
    knock sensor just below the oil filter...vag first but thats what my monies on
  3. bengal
    bengal Member
    537
    Possibly the fuel pump i take it there are no fault codes ? Or as above lol.
  4. 1animal1
    9,978
    fuel pump would cause more of an issue when cold that warm....
  5. motfree
    motfree Member
    464
    Knock sensor was on the diagnostics no1 and no2 I think !! What do these do ?
  6. 1animal1
    9,978
    its a snensor that fits in the block, only way is to replace....otherwise the situation will get worse
    make sure you get a car specifc one too as i got sent a golf one and it didnt work!! £40 wasted
  7. motfree
    motfree Member
    464
    Is there 2 sensors ? Might just take it the garage and let them sort it out .. If it makes it haha ..
  8. 1animal1
    9,978
    nope just one..... and its a royal pain in the ass without a ramp....you have to remove the undertray and the mount at the front of the inlet manifold, undo the securing nut from the top then remove the sensor out the bottom, arse of a job
  9. Welly
    Welly VX220 SC Driver :)
    10,696
    127
    Don't you mean crank speed sensor dude? That's what I would put my money on....
    There are indeed 2 knock sensors.
