S3 SD card slots and spare wheel
kenny_boon Dec 29, 2013
  1. kenny_boon
    kenny_boon Active Member
    466
    71
    Hi all,
    Forgot to ask this before but I think I'm right saying each S3 comes with 2 SD card slots, 1 will be used for sat nav if and when fitted and the other for music storage and the likes?
    I was wondering how large an SD storage capacity can the car handle?
    Last question, with most cars you need to spec a spare wheel, is the A3 different and u always get a wheel?
  2. Schizophonic
    Schizophonic Well-Known Member
    770
    378
    With the SD- yes you are correct in that there are two. I think the total max size you can have is 64GB?
    Why anyone needs more than that is beyond me unless they are using their card as a secondary back up.
    Not sure on the S3 about the spare wheel but you ALWAYS get a spare wheel. Even if you opt for the B&O sound system the sub still manages to sit on top of the spare wheel.
    Never heard of specing a spare wheel...
  3. snowfree52
    snowfree52 Full LED baby !
    522
    125
    43
    my 128Gb is working just fine
  4. Cumbrian_bob
    Cumbrian_bob Member
    227
    103
    My last A1 as with a number of cars now come with tyre weld goop rather than a spare wheel. In the current climate of better MPG alongside the reality most peole dont get punctures so often its not actually a bad idea. The A3 being a smaller car would have been a good candidate for the no spare wheel as standard. Im a little happier it isnt, I still like the confidence of a real wheel (space saver) if needed. Not so long ago the spare wheel was a real wheel, and some cars even had the spare on a matching alloy wheel.
  5. kenny_boon
    466
    71
    Thanks for the replies everyone :)
    I'm looking at a 64gb SD as my music library is over 32gb already.
    As for the spare wheel I'm glad we get a spare, our new octavia we had to spec it :( same with many other cars like the Q5 etc
  6. cuke2u
    cuke2u Well-Known Member TFSI Owners Group Audi A4 S-line owners group saloon
    5,062
    1,380
    The sd slots can take up to 2tb cards according to the specs...
    cemerson likes this.
  7. cemerson
    cemerson Well-Known Member Team Cosmos quattro Audi A3 S-line owners group TDi DSG
    4,362
    1,061
    You only get a spare if you spec it on the A3 now as well - that's a recent change. By default it comes without one now, unless you order the towbar, or either of the upgraded sound systems (I presume just so the sub has somewhere to sit!). That's how it is on the configurator now anyway. I'm glad I have one though, needed to use it when my car was barely 2 weeks old! Tyre goop would have done nothing for the puncture I had, it was total tyre annihilation!
  8. h5djr
    9,187
    1,578
    Do you think the spare wheel well would actually take a full-size wheel and tyre. With my existing 8P Sportback I have some foam parts that I purchased from Audi which build-up the floor level so that I can carry a full-size steel wheel and tyre as the spare. This is mainly because I don't fancy a space-saver when I'm on my long runs through France to Germany and also as I normally go on a Sunday the chances of getting anyone to sort out a new tyre in France on a Sunday is a bit remote.
    Mind you the last time I had a puncture I had to call Audi On-Call because I could not get the alloy wheel to part from the hub. The RAC chap said it is quite common and they have a rubber hammer with a lead weight inside the head which usually does the trick.
  9. cemerson
    4,362
    1,061
    I know from putting my wheel in there when I had to use a space saver that it does fit, as long as the boot floor is in the higher position. I didn't try to put the sub in either, just kept it separate until I had the tyre fixed.
  10. h5djr
    9,187
    1,578
    Thanks, that's nice to know. Audi always used to supply a large strong plastic bag to put the damaged wheel and tyre in. It was part of the tool kit in the luggage area. Do they still do this.
  11. cemerson
    4,362
    1,061
    I haven't noticed, not tried looking for it. Didn't notice it in the tool kit with the locking wheel nut and brace though, but don't think I'd have bothered anyway. Suppose it would be useful if you were just dumping it in the boot or something but I just put it back under the boot floor.
  12. kenny_boon
    466
    71
    Never had this on my last audis unless I missed it. Sorry
  13. h5djr
    9,187
    1,578
    It was certainly there on my 2007, 2009 and my current 2012. I used on the 2007 and 2009 to put my full-size spare into so that I could carry it inside the car, behind the passenger seat. With my current 2012 I purchased some foam parts from Audi which build up the floor so that the spare can be carried under the floor in the luggage area.
  14. Psyman79
    Psyman79 Sarcasm is hard on a forum ;) Team Vegas Yellow Audi S3
    856
    668
    93
  15. kenny_boon
    466
    71
    How do you connect it to the car mate?
  16. Psyman79
    856
    668
    93
    the_lecht_rocks likes this.
  17. kenny_boon
    466
    71
    Brilliant mate, had no idea you could do that :)
    Are you meant to get cables free?
  18. ddscot
    ddscot Member
    61
    Probably not, I had ipod one in the glove box which might be the standard token offering but I can't see them saying no on collection after having shelled out so much on the car if you ask nicely.
  19. Battlekrapz
    Battlekrapz Active Member
    418
    241
    43
    I got a USB cable and iphone 4 cable free with my car.
  20. Leeber
    Leeber Active Member
    234
    98
    Aside from the difference in capacity, is their any difference in functionality between using a portable HD over an iPod touch? I ask because I have both, could really do with keeping the iPod at home as a Sonos controller. My car's going to have the tech pack with Audi connect.
  21. ivicyrusivi
    ivicyrusivi Active Member
    157
    Wait... What? When did they remove the spare wheel? Arghhh was glad that they weren't giving away that stupid goop anymore!
    Anyone know how much the space saver wheel is?
  22. Itguy
    Itguy Well-Known Member
    1,130
    449
    It's a no cost option when ordering.
  23. cemerson
    4,362
    1,061
    Only in combination with towbar, Audi sound system or B&O. You have to have one (or more) or those in order to have the spare wheel, and the wheel is free then. It doesn't seem to let you select the wheel only, even as a paid option.
  24. Itguy
    1,130
    449
    Interesting - it did earlier on a a3 SB 1.8tfsi manual I created? (Wasn't a Quattro).
    Didn't have any other options ticked and it let me??
  25. cemerson
    4,362
    1,061
    Oh, when I pick the spare for the 2.0 TDI it makes me select one of those in addition
  26. cemerson
    4,362
    1,061
  27. Psyman79
    856
    668
    93
    You should get at least 1 free. I got an iphone cable and a normal usb one. I think there are 5 available, the 2 i got plus a micro usb, aux and i think there is a new style iphone one.
    Si.
    kenny_boon likes this.
  28. Psyman79
    856
    668
    93
    I wouldn't have thought so, you just plug in and control through the MMI. Not sure how Apple file structure works as i've never had an iProduct. I'm sure i read on here somewhere that you can play videos through tech pack with an iPod though. Not sure if it'll work from HDD as i've only got the SD sat nav upgrade.
    Si.
  29. Ade44
    Ade44 New Member
    19
    Hi Guys, Happy New 8V Year
    If you look in "Standard Equipment" tab in the A3 configurator it says Space Saver is standard without the sound system upgrade. On the 8P you had to order it separately in place of gloop at the dealers. No gloop on the 8V
    Without roof rails
    Xenon Plus headlights
    Tyres
    Anti-theft wheel bolts
    Space-saving spare wheel
    Tool kit and car jack
    18” x 7.5J ‘5-parallel spoke’ design part-polished alloy wheels with 225/40 R18 tyres
    Interior
    Aluminium interior elements
    Cloth headlining in black
  30. cemerson
    4,362
    1,061
    There are a lot more than 5 available, there are several video ones, a mini USB as well, another different Apple one (red / blue collars, they look the same other than that), all sorts
  31. cemerson
    4,362
    1,061
    Could be a mistake from when it changed though - worth checking this is actually the case.
  32. ivicyrusivi
    157
    Have the b&o, so hope this hasn't changed... Will be calling dealer tomoz to check!!
  33. cemerson
    4,362
    1,061
    Would be very surprised if you don't get the spare then, as the sub for the 2 sound systems needs one to sit in!
