S3 s-tronic "grunt" when shifting explanation...
Ziggyma89 Jan 13, 2014
  1. Ziggyma89
    Ziggyma89 Member
    65
    12
    Can anyone explain where the actual sound comes from and why it does this?
  2. keyser
    keyser Active Member Audi S3
    118
    57
    My understanding is that it's a backfire caused on downshifts by engine braking.
    Is it on downshifts only? (Mine's a manual s3.) If on upshifts as well, then also a backfire but probably caused by an intentionally rich mix, leaving fuel to enter the exhaust system.
    Happy to be corrected obviously...
    Ziggyma89 likes this.
  3. Ziggyma89
    Ziggyma89 Member
    65
    12
    From what I've seen on videos is that it happens wen up shifting. The dealer also said it makes a sound when downshifting too. Ordered the s tronic. only got to test drive the manual
  4. Silky-S3
    Silky-S3 Is loving his new 8V S3!
    1,407
    343
    Happens on upshift mostly, sweet spot is about 6250rpm. ECU throwing load of fuel in when shifting to richen up the mixture and ignite it in the exhaust. Sounds awesome.
    Aran383 likes this.
  5. Ziggyma89
    Ziggyma89 Member
    65
    12
    Thanks lookin forward to it!!!
  6. lotus
    lotus Member
    75
    It's strange how the sound of a badly tuned engine is used to purvey power, that said I like it, though I'm getting a manual so won't have it.
  7. cuke2u
    cuke2u Well-Known Member TFSI Owners Group Audi A4 saloon S-line owners group
    6,593
    2,005
    I have heard that the exhaust has flaps inside them which will cause the 'pops'.
  8. Cumbrian_bob
    Cumbrian_bob Member
    227
    104
    I have only noticed it on the upshift, but you also get to hear it make a little burble on the efficiency mode when the power goes off when it goes into coasting downhill.
    You can also amend the level of noise from the MMI, not sure which parts this turns off. I have this setting on individual mode so I can has the sporting steering and accelarion but not the louder noise.
    I am guessing the attenuator (speaker) and the exhaust flaps are available on both manual and Stronic S3s, and more for normal engine sound not just the gear change sound.
    r500frs likes this.
  9. Chimp
    Chimp Active Member Team Navarra Audi S5 Audi Q5
    208
    51
    On the test drive of a Manual I managed to get a slight pop on upshifts when I was driving "enthusiastically". On the S-tronic test drive it pops every gear change and in sport mode it poped on downshifts too. Also noticed the box auto "blip" the revs on downshift.
  10. rams_s3
    rams_s3 Active Member
    381
    144
    43
    I need to learn that one seen as mines manual!
  11. Joetidman
    Joetidman Well-Known Member
    1,103
    582
    I was told by the dealer, its actually an small bit of additional fuel injected specifically at that point and the sound is it being burnt off in the exhaust. I actually love the fact that Audi built it in. Fuel being wasted just to make a great noise, not very Audi!
  12. Dan_G
    Dan_G Well-Known Member Team Navarra Audi S3 SQ5 owners group
    368
    256
    Doesn't do it in Eco mode I don't think.
